Finding the Height of a Triangle Using Related Rates
  • Context: Undergrad
  • Thread starter Thread starter franz32
    Related rates Triangle
The discussion focuses on calculating the height of a triangle using related rates, given two sides increasing at 0.5 feet per second and an included angle decreasing at 2 degrees per second. The specific scenario involves sides measuring 5 feet and 8 feet, with an included angle of 60 degrees. The area of the triangle can be expressed using the formula Area = (1/2) * base * height, where the height is derived from the right triangle formed by dropping a perpendicular from one side to the base. The use of vector cross products is suggested for a more efficient area calculation.
  • Understanding of related rates in calculus
  • Familiarity with triangle area formulas
  • Knowledge of trigonometric functions and right triangles
  • Basic concepts of vector mathematics
  • Study the application of related rates in calculus problems
  • Learn about the Law of Cosines for triangle calculations
  • Explore vector cross products and their applications in geometry
  • Investigate advanced triangle area formulas involving angles and sides
Students and educators in mathematics, particularly those focusing on calculus and geometry, as well as professionals needing to apply related rates in engineering or physics contexts.
franz32
Hello here's the problem:
Each of the two sides of a triangle are increasing at the rate of 1/2 foot per second, and the included angle is decreasing 2 degrees per second. Find the rate of change of the area when the sides and included angle are respectively 5ft., 8ft., and 60 deg.
Here is my question: How do I find the height of the triangle?
Say my base is 5ft. How do I express it in terms of the given details in the problem?
Try finding a better formula for the area of a triangle involving the two given sides and the included angle. (Think vector cross products, perhaps.)
Area= (1/2) height times base where the "height" is measured perpendicular to the "base". Take one of the given sides as base, and drop a perpendicular to it. The other given side is the hypotenuse of the right triangle formed. The height you need is the "opposite side" of that right triangle.
  • · Replies 38 ·
