Thermo question - final mass/entropy generation
The discussion revolves around a thermodynamics problem involving an insulated tank filled with air, focusing on calculating the final mass of air and the entropy generated during the cooling process. The scope includes theoretical analysis and mathematical reasoning related to gas laws and thermodynamic equations.
  • Homework-related
  • One participant presents a problem involving an insulated tank and seeks to determine the final mass of air and the entropy generated during cooling.
  • Another participant questions the use of the gas constant value and the temperature used in calculations, suggesting that the participant may have used the wrong temperature in their pressure calculation.
  • A later reply acknowledges a mistake in using the initial temperature instead of the final temperature for the pressure calculation and provides a revised mass calculation.
  • Concerns are raised about the units used for the gas constant and specific heat capacity, indicating a need for consistency in units when performing calculations.
  • Further clarification is sought regarding the variables used in the ideal gas equation and the relationship between mass and moles in the context of the problem.
Participants express differing views on the correct values and units to use in calculations, indicating that there is no consensus on the correct approach or final answers at this stage.
Participants highlight potential issues with unit consistency and the need for careful consideration of the variables involved in the equations, but these points remain unresolved.
goblue88888
I think I may have posted this in the wrong forum earlier :\
An insulated and initially empty 0.7m^3 tank is connected by a valve to a line flowing air at 50degreesC and 200kPa. The valve is opened until the tank is filled, and then the valve is closed. The insulation is then removed from the tank, and a 20degreeC heat sink cools the tank until the air inside reaches a temperature of 30degreesC. 1) What is the final mass of air in the tank? 2) How much entropy is generated during the cooling of the tank?
PV=mRT
2)
S2-S1=Cp*ln(T2/T1)-R*ln(P2/P1)
m(s2-s1)=Integral(dQ/T)+S-gen
1) I tried figuring out the final temperature, and since V and R are constant, I got P2=P1*T2/T1=200kPa*303K/323K=187.62kPa. I then used this P to get m=PV/RT. So m=(187.62*0.7)/(0.287*323)=1.417kg.. Is this right?
2) Using the first equation, I get 1.004*ln(303/323)-0.287*ln(187.62/200)=-0.0458.. But this is wrong right since it shouldn't be negative?
Then I try putting it into the second equation, 1.417*-0.0458 - Integral(dQ/303)=S-gen.. but I don't know how to do the Integral and dQ part... any help? THANKS!
Write out your units for the gas constant... you have 0.287 for the value (its wrong).
In 1), you are using the pressure you calculated at the final temperature, P2. What temperature are you using in your calculation, T1 or T2?
You can't do 2) until you figure out what value to use as the gas constant.
Thanks chemisttree for your response!
For 1).. I accidentally put in T1! Oops!
P2 = P1*T2/T1 = 200kPa*303K/323K = 187.62kPa
So it should be (187.62kPa*0.7m^3)/(0.287kJ/kg-K*303K) = 1.51kg.
However.. isn't 0.287kJ/kg-K correct since it's the R for air? :\ Not R-bar or anything else.
What is 'm' in PV=mRT? Is it mass? Should it be 'n' or moles? Did you do a calculation like n=m/M where m is mass of air and M is molar mass of air?
In the equation
S2-S1 = Cp*ln(T2/T1) - R*ln(P2/P1), what units did you use for Cp? Value is 1.004. It seems to me that the units should be the same as that for R since you are performing a subtraction.
Look at your units for the calculation that yields 1.51 kg. Just write down the units and you get an answer that will be in units of KPa m^3 kg K/kJ K.
Is a kJ equal to KPa*m^3?
I would suggest writing out all of the equations you intend to use and identify the units that you will use. Tabulate your known information in a table that expresses the information in the units you have identified. Substitute into the equations you are given and solve.
  • · Replies 20 ·
9K
