Can G-Force and Displacement Predict Fuel Consumption in a Turning Car?
The discussion revolves around the relationship between g-force experienced by a car during a turn and the displacement of fuel in the tank, as well as a similar scenario with water in a bottle. Participants explore mathematical relations and geometric representations related to this concept.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant introduces the scenario of a car turning at 50 km/h and questions the mathematical relationship between g-force and fuel displacement.
  • Another participant suggests that the problem can be visualized using a triangle formed by the two g-forces, implying a geometric approach to the solution.
  • A subsequent post clarifies that the resulting angle refers to the tilt of the water's surface, prompting questions about the specific g-forces involved.
  • A participant provides a specific example, calculating the angle of tilt based on a lateral g-force of 0.5, using the arctangent function.
  • One participant expresses appreciation for the simplicity of the explanation while acknowledging the complexity of the topic.
  • A later post requests references for further reading on the subject, indicating a desire to deepen understanding.
Participants appear to engage in a constructive exploration of the topic, with no clear consensus or resolution of disagreements present in the discussion.
Some assumptions about the definitions of g-force and displacement may not be explicitly stated, and the mathematical steps involved in the calculations are not fully resolved.
ca2n
hi..just discovered this forum..very nice indeed..i was wondering if somebody could help me on something here..imagine that a car is traveling at 50km/h through a 90-degree right-hand turn..my question is is there any mathematical relation relating how much the g-force he encounters and the "displacement" of fuel in the fuel tank..or water that is half-full in a water bottle..tq..
Yes, it is a simple matter of drawing a triangle witht he two g-forces as two legs and computing the resulting angle.
so, the resulting angle is the angle at which the top surface of the water is tilted? what are the two g-forces? the ones acting on the car?
Right. So, for example, if the lateral g-force on the car is .5, the angle is atan (.5/1)=26.6 degrees.
Neat, thanks Rus. Never thought of that. Simple and elegant.
wow..simple and complicated at the same time..i was also wondering if you any reference books in particular regarding this topic..i guess i need to catch up on my reading..
  • · Replies 0 ·
  • · Replies 82 ·
29K
  • · Replies 52 ·
9K
  • · Replies 152 ·
12K
  • · Replies 0 ·
