Can a subring exist in the same domain as its parent ring?
  • Thread starter Thread starter pivoxa15
    Domain
The discussion revolves around the relationship between a subring and its parent ring within the context of specific domains, such as Unique Factorization Domains (UFDs). Participants explore whether a subring retains the properties of the domain it resides in, particularly focusing on examples involving the integers and modular arithmetic.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants examine examples of subrings and question the implications of their properties, such as whether a subring can be a field while its parent ring is not. There is also exploration of the definitions and requirements for a subring, particularly in relation to being a subset and satisfying ring properties.
The discussion is ongoing, with various interpretations being explored. Some participants provide examples to support their points, while others raise questions about the definitions and properties of subrings and domains. There is no clear consensus yet, as differing views on the examples and definitions continue to emerge.
Participants are navigating the complexities of ring theory, particularly the definitions of subrings and the implications of being in a specific domain. There are references to specific examples, such as Z mod p and its relationship to Z, which are under scrutiny for their validity as subrings.
pivoxa15
If A is a subring of B and B is in a particular domain like a UFD than does it imply A is also in that domain B lives in hence also a UFD?
Z is a ring but not a field. However Z mod p is a field. And Z mod p is a subring of Z. Although Z mod p is a ring also so a subring may live inside a more 'specialised' domain but can always be denoted the name of the domain it is a subring of. So the answer is yes to my above question.
Actually it is possible to construct a subring of the rationals which is a field such that this subring is not a field. So the answer is no. i.e the subring could be all fractions in Q such that the denominator does not contain a factor integer.
Z mod p is definitely not a subring of the integers.
Also, fields are a silly thing to talk about as UFDs since every element is a unit. And why is your second example (the p-locals) not a UFD? Suppose we choose
Z_{(p)} = { a/b in Q such that hcf(b,p)=1}
then the only non-units are powers of p, and those factorize uniquely into irredicuibles (up to units). More mathematically it is a PID - the ideals are those of the form (p^r).
Why 'Z mod p is definitely not a subring of the integers'?
Is it because for A to be a subring of B, A must satisfy being a ring and also the properties of B? i.e Z is not a field but Z mod p is so the latter can't be a subring of Z? But 'properties' is a vague word.
I took UFD just as an example.
So the answer to " If A is a subring of B and B is in a particular domain D then A must also be in that domain D" true? What about the converse?
The only subring of Z is Z.
Z mod p and Z disagree arithmetically -- for example, the value of (p-1) + 1.
And technically, Z mod p isn't even a subset of Z. (Although we might pretend, for convenience)
By "in", I will assume you meant "is a subset of", "is a subring of", "is a subdomain of", or something like that.
If A is a subring of D then A is a subring of B and B is a subring of D is clearly false. For example, pick A = Q, D = Q, and B = Z.
I'm not sure which converse you meant, but I suspect it's not true. And I bet the domain Z[x] and its subdomains Z[x^2] and Z[x^3] will yield a counterexample.
It isn't because it isn't. The map sending 1 in Z/pZ to 1 in Z does not define a ring homomorphism, and is nothing to do with one being a field, and the other not. Z/mZ for m composite is not a field, and not a subring of Z. Q is a field, and it is isomorphic to a subring of M_2(Q) [2x2 matrices over Q], which is not a field.
As Hurkyl points out, Z/pZ isn't even a subset of Z, but it is also not isomorphic to a subring of Z either.
  • · Replies 21 ·
  • · Replies 17 ·
