Change in Tension & Fundamental Frequency of a String
The discussion focuses on the relationship between tension changes in a stretched string and its fundamental frequency. It establishes that a small change in tension, denoted as ΔF_T, results in a corresponding change in frequency, represented by Δf = 1/2 (ΔF_T / F_T) f. The derivation utilizes the wave velocity formula v = √(T/μ) and applies binomial expansion to approximate the frequency change. The final result confirms that the frequency change is directly proportional to the change in tension over the initial tension.
  • Understanding of wave mechanics and transverse waves
  • Familiarity with the concepts of tension and mass per unit length (μ)
  • Knowledge of binomial expansion and its application in approximations
  • Basic algebraic manipulation skills
  • Study the derivation of wave velocity in different mediums
  • Learn about the effects of tension on wave properties in strings
  • Explore advanced applications of binomial expansion in physics
  • Investigate the relationship between frequency and tension in musical instruments
Physics students, educators, and anyone interested in the mechanics of waves and their applications in musical acoustics.
e(ho0n3
[SOLVED] Change in Tension & Fundamental Frequency of a String
Problem. Show that if the tension in a streched string is change by a small amount [itex]\Delta F_T[/itex], the frequency of the fundamental is changed by a small amount [itex]\Delta f = 1/2 (\Delta F_T / F_T) f[/itex].
Let T be the intial tension and h the change in tension. The velocity of a transverse wave on the string is [itex]v = \sqrt{T/\mu}[/itex]. The initial frequency is
[tex]f = \frac{v}{\lambda} = \frac{\sqrt{T}}{\lambda \sqrt{\mu}}[/tex]
The new frequency f' is
[tex]f' = \frac{v'}{\lambda} = \frac{\sqrt{T + h}}{\lambda \sqrt{\mu}}[/tex]
The difference is:
[tex]f' - f = \frac{1}{\lambda \sqrt{\mu}} \, (\sqrt{T + h} - \sqrt{T})[/tex]
That looks nothing like what I'm trying to show. Now, if I multiply the RHS by [itex]\sqrt{T} / \sqrt{T}[/itex], I get
[tex]f' - f = \frac{\sqrt{T + h} - \sqrt{T}}{\sqrt{T}} \, f[/tex]
and if I do it again, I get
[tex]f' - f = \frac{\sqrt{T(T + h)} - T}{T} \, f[/tex]
which is as close as I could get to what needs to be shown.
binomial expansion
[tex]\sqrt{T + h} = \sqrt{T}(1 + h/T)^{1/2}[/tex]
Hint: Approximate that expression by taking a binomial expansion to first order in h/T. (Note that h/T << 1)
Great hint! I never considered it. The approximation is given below:
[tex]\sqrt{T(T + h)} = T + 1/2 \, h[/tex]
and so
[tex]f' - f = \frac{T + 1/2 \, h - T}{T} \, f = \frac{h}{2T} \, f[/tex]
Thanks.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 29 ·
