Solving Variance Problem - Hi All
  • Context: Undergrad
  • Thread starter Thread starter Asuralm
    Variance
The discussion centers on modifying a dataset V with a mean of 0 and variance var(V)=x to achieve a new variance var(V_hat)=y. The original poster attempted to calculate the necessary error adjustment using the formula delta = sqrt[(y-x)*(n-1) / n], but found it ineffective. A more straightforward solution was provided, suggesting that multiplying each element of V by sqrt(y/x) effectively achieves the desired variance. This method simplifies the process of variance adjustment in datasets.
  • Understanding of variance and standard deviation in statistics
  • Familiarity with basic algebraic manipulation
  • Knowledge of dataset normalization techniques
  • Experience with statistical software or programming languages for data manipulation
  • Research variance adjustment techniques in statistical analysis
  • Learn about dataset normalization methods in Python using NumPy
  • Explore the implications of variance changes on data distributions
  • Study the properties of variance in relation to linear transformations
Data scientists, statisticians, and anyone involved in data analysis or manipulation who seeks to understand variance adjustment techniques in datasets.
Asuralm
Hi all:
If I have a dataset V of the size n*1. Assume that the mean of the dataset is 0 and var(V)=x is its variance. If I want to modify this dataset so that the variance of the new dataset will be var(V_hat)=y. The errors are spreaded average on each element in the dataset. What I did is first calculate the error which need to be speaded on each elements
v_hat - v = delta = sqrt[(y-x)*(n-1) / n] (0)
because
var(V) = x = sum(v^2)/(n-1) (1)
var(V_hat) = y = sum(v_hat^2)/(n-1) (2)
(2)-(1) and rearrange I got the equation (0);
However, this didn't give me the supposed answer. Could anyone point out what's the error in this or if there is any better methods please?
Thanks a lot!
I am not sure what limits you have on the modification. However, you can multiply each element of V by sqrt(y/x) to get what you want.
What a nice and easy way. How stupid I am. Thanks a lot!
  • · Replies 42 ·
  • · Replies 17 ·
