Plank's law - my computer is having trouble with the formula
The discussion centers on the application of Planck's law, specifically the formula for spectral radiance, f_λ(T) = (2πhc²/λ⁵) / (exp(hc/λkT) - 1). A user encountered computational difficulties when calculating the exponent due to an incorrect value for Planck's constant, initially using 6.626068e-24 instead of the correct 6.626068e-34. This error resulted in an unmanageable exponent value. The user was advised to compare the magnitudes of terms in the formula to identify dominant factors, which is a common approach in simplifying complex calculations.
  • Understanding of Planck's law and its formula components
  • Familiarity with scientific notation and significant figures
  • Basic knowledge of exponential functions and logarithms
  • Proficiency in using a scientific calculator or programming language for calculations
  • Review the derivation of Planck's law and its implications in physics
  • Learn how to use logarithmic transformations to simplify calculations
  • Explore numerical methods for handling large exponentials in programming languages like Python
  • Investigate the significance of precision in physical constants and their impact on calculations
Physicists, students studying thermodynamics, and anyone interested in the application of Planck's law in real-world scenarios.
tony873004
Plank's law -- my computer is having trouble with the formula
[tex]f_\lambda \left( T \right) = \frac{{2\pi hc^2 /\lambda ^5 }}{{\exp \left( {\frac{{hc}}{{\lambda kT}}} \right) - 1}}[/tex]
I'm guessing this thing wants wavelength in meters. So for a temperature of 5600 K and a wavelength of 0.5 um (5e-7 m), the part that I'm using as the exponent for e, [tex]{\frac{{hc}}{{\lambda kT}}}[/tex] comes out to (6.626068e-24*2.99792458e8/(5e-7*1.3806503e-23*5600)) =51384823425.8871.
And e^51384823425.8871 is not a number my computer can calculate.
How can I use this formula?
Not a complete solution- but worth trying.
ln(f(T))=ln(2pi h c^2/lambda^5)-hc/lambda k T
Accurate to a lot of sig. fig.
Compare the magnitude of the two terms on the RHS to see if one dominates by orders of magnitude.
Thanks. Someone in the math department at school recommended the same thing. However, my value for plank's constant turns out to be wrong. I must have made a typo. it's e-34, not e-24. This turns the value fed to exp( ) from5.138e10 into a managable 5.138.
Thanks for your reply.
  • · Replies 28 ·
10K
15K
19K
