2 Derivations of Solenoid's Magnetic Field - Problem
The discussion focuses on deriving the magnetic field inside a solenoid using two methods: Ampere's Law and integration of the magnetic field from a single ring. The first method yields the equation B = (μ₀NI)/(L), while the second method gives B = (μ₀NI)/(2L) under the approximation L >> R. The discrepancy arises due to the limits of integration used in the second method, which leads to an asymmetry in the field calculation. For an accurate comparison, the integration should be symmetric around the solenoid's center, resulting in a consistent expression with Ampere's Law.
  • Understanding of Ampere's Law and its application in electromagnetism
  • Familiarity with magnetic field calculations for solenoids
  • Knowledge of calculus, specifically integration techniques
  • Concept of limits and approximations in physics
  • Study the derivation of magnetic fields using Ampere's Law in various geometries
  • Learn about the concept of infinite solenoids and their properties
  • Explore advanced integration techniques for calculating fields from continuous charge distributions
  • Investigate the effects of solenoid length and radius on magnetic field uniformity
Physics students, electrical engineers, and researchers in electromagnetism who are interested in understanding the behavior of magnetic fields in solenoids and the implications of different mathematical approaches to field calculations.
sprinkler
Hello,
I have been asked to find the magnetic field inside a solenoid (along its axis)using two methods. One is using Ampere's law (and the approximation that the B field is zero outside the solenoid). Here is what I get:
B = (uIN)/(L)
where I is current, N is the number of loops, and L=length of solenoid.
The other method is integrating the equation for the B field of a single ring, over the length of the solenoid. Here is what i get:
B = (uIN)/(2L) * [ Z/(R^2 + Z^2)^(1/2) - (Z-L)/(R^2 + (Z-L)^2)^(1/2) ]
where R is the radius of the solenoid, Z is the location on the "z" axis where I wish to calculate the magnetic field. (Can also be seen here: http://www.netdenizen.com/emagnettest/solenoids/?thinsolenoid)
Now with this second equation, if I make the approximation that L>>R, it boils down to this:
B = (uIN)/(2L)
(basically only the initial constants remain, the rest of the equation ends up equaling one)
However this is not what I found with amperes law, there is an extra factor of (1/2). Can anyone explain why?
The reason why is subtle and has to do with how you did the integral and what it means to let the length become large relative to the radius. You took the limits of integration from zero to ##L## and then allowed ##L## to become large. That is not an infinite solenoid, it is a semi-infinite solenoid because it starts at z = 0 and points closer to that end have a different field than points farther in because of the asymmetry.
In an "infinite" solenoid every point on the axis must be equivalent to any other point, i.e. all points must be equally far away from the ends. That is achieved if you place the origin in the middle and integrate over symmetric limits from ##(-L/2)## to ##(+L/2)##. In that case you get $$B(z)=\frac{\mu_0NI}{2L}\left(\frac{z+\frac{L}{2}}{\sqrt{\left(z+\frac{L}{2}\right)^2+R^2}}-\frac{z-\frac{L}{2}}{\sqrt{\left(z-\frac{L}{2}\right)^2+R^2}}\right).$$ When ##L>>z,R##, this expression reduces to the one obtained using Ampere's law.
