Efficiently Dropping Voltage: What's the Best Method?
The discussion centers around methods for efficiently reducing the voltage from a 10v lithium-ion battery to 6v DC, specifically for use in a bike light application. Participants explore various approaches, including adjustable voltage regulators, diodes, and switching regulators, while considering efficiency and size constraints.
  • Experimental/applied
  • One participant inquires about the most efficient method to drop voltage, suggesting options like adjustable voltage regulators or diodes.
  • Another participant argues that all power lost in the drop can be minimized by using a switching regulator, mentioning the LM317 as a simple linear regulator option.
  • A different participant asserts that switching regulators are not significantly more difficult to use than linear regulators and are suitable for most applications.
  • A participant describes the specific application for a bike light, expressing concerns about efficiency and heat dissipation while aiming for a longer run time from the battery.
  • One participant shares a personal experience using a resistance unit to step down voltage for radios, indicating a practical solution that worked well for them.
  • Another participant notes that a well-designed switching power supply can achieve over 90% efficiency and suggests looking into specific regulator datasheets for more information.
Participants express differing views on the best method for voltage reduction, with some advocating for linear regulators and others for switching regulators. The discussion remains unresolved regarding the optimal approach, with multiple competing views presented.
Participants mention considerations such as heat dissipation, size constraints, and efficiency, but do not resolve the implications of these factors on the choice of voltage regulation method.
This discussion may be of interest to individuals working on electronics projects, particularly those involving battery-powered devices, as well as those seeking practical solutions for voltage regulation in compact applications.
couchsurf
Looking to drop a 10v Li-on battery to 6v DC. What is the most efficient way without to much wasted power. Adjustable voltage regulator? diodes?,
something else? needs to be small. Thanks
What do you mean by most efficient? All of the power of the drop will be lost unless you are willing to do a switching regulator.
The simplest way would be to us an adjustable linear regulator of the appropriate power rating. The LM317 is the jellybean part that is used for this application:
http://www.national.com/pf/LM/LM317.html
You can make a circuit with a power transistor and two resistors, to give you some fairly stable voltage drop, but it varies with temperature a little bit, and is not as stiff as using the LM317. And the two options are about the same in size.
Remember that you need to dissipate that heat somehow, and keep it away from the battery itself. Use appropriate heat sinking or some other option to get rid of the heat.
EDIT -- fixed typo "power resistor and two resistors" -> "power transistor and two resistors" (jeeze)
Switching regulators are not really any more difficult to use than linear regulators. For most applications, switchers are perfect.
- Warren
The application it will be used for is a bike light. 6v 15w bulb, the battery is a 10.8v 3.6 Ah that is doing nothing right now. I figure a burn time of about 2.5 hrs with this if I get it down to 6 volts. Because its on a bike I wanted to keep it small. Also thinking about a digital controller. Efficiency? I didn't want to have the 4 extra volts being turned into heat vs. getting a longer run time from the battery, but I'm not sure what is possible.
I found an old 6volt resistance unit on the fire wall of a junked car. For years I used it to step down twelve volts to six volts for small radios on the sailboat. It worked great!
A well designed switching power supply is typically over 90% efficient. <EDIT: took out sentence here..> Take a look at National's LM5005 regulator datasheet, which includes circuits.
This is a fun project, but if you are looking for an easy approach then buy a bike light!
  • · Replies 32 ·
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 34 ·
10K
  • · Replies 23 ·
