Thread Closed
Calculation Help Needed...
Share Thread Thread Tools
Apr7-07, 07:45 AM   #1
Air
Recognitions:
Gold Membership Gold Member
Lightbulb
Find the mass:
2. Relevant equations
Not Sure.
3. The attempt at a solution
I don't know where to start as I believe that there is less information.
All that I have got upto is Tan-1(3/8) but I don't know if this is needed to find the mass?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr7-07, 07:48 AM   #2
Recognitions:
Retired Staff Staff Emeritus
I'm assuming the frame is massless, pivoted bout the right angle of the triangle and the system is in equilibrium, am I correct?
Apr7-07, 08:51 AM   #3
Air
Recognitions:
Quote by Hootenanny
Yes, You are correct.
Apr7-07, 08:57 AM   #4
Recognitions:
So, we know that since the system is in equilibrium, the sum of the moments about any point should be zero. However, lets consider the forces; if the system is not translating (i.e. moving up or down) what must be the vector sum of the vertical forces?
Apr7-07, 08:59 AM   #5
Air
Recognitions:
Quote by Hootenanny
Erm...Not sure but guessing zero.
Apr7-07, 09:06 AM   #6
Recognitions:
Sounds good to me and where will this reation force be applied?
Apr7-07, 09:12 AM   #7
Air
Recognitions:
Quote by Hootenanny
Either at the angle at the end of Y or near the mass?
Apr7-07, 09:18 AM   #8
Recognitions:
Normal forces are applied at the point where the system pivots. Just checking, is the side x attached to a wall of some kind?
Apr7-07, 09:21 AM   #9
Air
Recognitions:
Quote by Hootenanny
Nope. The pivot is at the corner of x and y.
x and y dimensions are given if to calculate the angle (I think).
Apr7-07, 09:31 AM   #10
Recognitions:
Okay, let us consider the torques about the pivot point;
[tex]0.08T\sin\left(\arctan\left(\frac{3}{8}\right)\right) = 0.4mg[/tex]
Where T is the tension in the diagonal member. Do you follow?
Apr7-07, 09:38 AM   #11
Air
Recognitions:
Quote by Hootenanny
Yes, I do.
Apr7-07, 09:56 AM   #12
Air
Recognitions:
Quote by Hootenanny
Can Tension be calculated without mass?
Apr7-07, 02:50 PM   #13
Recognitions:
Homework Helper Homework Help
You still have not set up the equalibrium of FORCES, only of torques..
Also, for your information,
[tex]\sin(\arctan(x))=\frac{x}{\sqrt{1+x^{2}}}[/tex]
Thread Closed
Thread Tools
Similar Threads for: Calculation Help Needed...
Thread Forum Replies
Urgent help needed with volume calculation Biology, Chemistry & Other Homework 4
Solar energy calculation - help needed Introductory Physics Homework 3
calculation...could somebody help me please? Biology, Chemistry & Other Homework 2
calculation help Precalculus Mathematics Homework 2
