Particle Motion: Finding Position, Velocity, and Acceleration at a Given Time
The problem involves a particle moving along the x-axis with a velocity function given by vx = 5t^2 m/s. The initial position is stated as x0 = 1 m at t0 = 0 s, and the task is to find the position, velocity, and acceleration at t = 1 s.
  • Participants discuss the initial conditions and the implications of the velocity function on acceleration and position. There is a question regarding the initial velocity and whether it should be assumed to be zero. Some participants suggest using calculus to differentiate the velocity function to find acceleration.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been offered regarding the use of calculus for finding acceleration and position, but there is no explicit consensus on the correct approach yet.
Participants note that the equations for position and velocity may not apply directly due to the non-linear nature of the velocity function. There is also mention of potential errors in calculations, particularly regarding the integration and the initial position.
spin360
A particle moving along the x-axis has its velocity described by the function vx = 5t^2 m/s, where t is in s. Its initial position is x0 = 1 m at t0 = 0 s. At t = 1 s, find the position, velocity, and acceleration of the particle.
So from that equation... vx = 5t^2, x0 = 1m, t0 = 0s, t1 = 1s
v1 = v0 + at
x1 = x0 + v0 + (1/2)at^2
So for the velocity, I just plugged in 1s for t and got 5.0m/s, which is correct. I'm stuck on the acceleration and position though, and I'm thinking it's because I don't know what v0 is. I assumed v0 = 0 because don't you plug in 0 for t in the given function? Which then the answer is 0. Any thoughts?
Your right, the intial velocity is zero. You can now find the position and acceleration by noting that;
[tex]a = \frac{dv}{dt}\hspace{1cm}\text{and}\hspace{1cm}x = \int v dt[/tex]
When velocity does not vary linearly with time, acceleration is not constant, which means, those equations which hold only when acceleration is constant cannot be used. In this case, velocity varies with the square of time, plotting a graph of velocity versus time shows that the graph is a quadratic function, not linear.
For the position and velocity part, I think you can make it through. I don't know if you've learned basic calculus before but velocity v = dx/dt(change of position with respect to time) and a = dv/dt(change of velocity with respect to time). Differentiate the v(t) function and plug in t = 1s and you get the acceleration.
Ahh okay that makes sense. So I got the acceleration right, just by the derivative. I took the integral of 5t^2... which came out to (5t^3)/3... which gives me 1.667m for position. Webassign says that's incorrect?
Nevermind, I forgot to add 1m :-p
  • · Replies 29 ·
10K
