Crystal Field Model: True/False Questions for Octahedral Complex Ions
The discussion focuses on the Crystal Field Model (CFM) as it pertains to octahedral complex ions, specifically first-row transition metals. Key points include that two of the 3d orbitals point directly at ligands, and the high-spin case results in maximum unpaired electrons. Statement C is incorrect as a large crystal field splitting energy does not necessarily lead to a diamagnetic complex, while statement G is poorly worded but implies that ligand interaction affects orbital energy levels due to Coulombic repulsion.
  • Understanding of Crystal Field Theory
  • Knowledge of octahedral complex ions
  • Familiarity with 3d orbital configurations
  • Concept of diamagnetism and paramagnetism
  • Study the implications of ligand field strength on crystal field splitting energy
  • Learn about the differences between high-spin and low-spin configurations in octahedral complexes
  • Investigate the role of different ligands, such as Cl- and H2O, in crystal field splitting
  • Explore the mathematical representation of crystal field splitting energy in transition metal complexes
Chemistry students, particularly those studying coordination chemistry, educators preparing materials on the Crystal Field Model, and researchers interested in transition metal complexes.
SamTsui86
Which of the following are true for the Crystal Field Model of an octahedral complex ion? Consider ions to be from first-row transition metals.
a) Two of the 3d orbitals point directly at ligands
b) t2 orbitals are less stable than e orbitals
c) A large crystal field splitting energy results in a diamagnetic complex
d) The high-spin case gives maximum unpaired electrons
e) For a given ligand, Fe3+ increases splitting less than Fe2+
f) Cl- causes a greater increase in the crystal field splitting energy than does H2O
g) The splitting of energy (E) of 3d orbitals occurs in the ligands
I put acde and I am pretty sure I am right, what am I doing wrong?
The statement c isn't technically right and g is unclearly worded to me.
For statement C if there are an odd number of electrons it is still diamagnetic. By most standards diamagnetic means no unpaired electrons and if there are an odd number electrons it going to have to be unpaired. A large splitting energy makes it hard to move the electons up in energy to the Eg orbitals but the unpaired electron can occur in T2g orbitals
Statement G: Crystal field theory assumes coulombic repulsion. The ligands attach on the axis making a higher electron density on those 2 d orbitals. This increases the repulsion and that is why those two orbitals split and become higher in energy. So in a way the splitting energy does come the ligands
  • · Replies 26 ·
