| Thread Closed |
Coupled differential equations |
Share Thread | Thread Tools |
| Apr9-07, 03:30 AM | #1 |
I need to find the general solution for: [latex]R \frac{dQ_{1}}{dt} + \frac{1}{C}(Q_{1}-Q_{2})=0[/latex] [latex]R\frac{dQ_{1}}{dt} + L\frac{d^2Q_{2}}{dt^2}}=0[/latex] For the case [latex]R=1\times 10^3[/latex], [latex]L=4\times 10^{-3}[/latex], [latex]C=1 \times 10^{-9}[/latex]. 3. The attempt at a solution As an attempt I looked for solutions of the form, [latex]Q_{1}=q_{1}e^{at}, Q_{2}=q_{2}e^{at}[/latex] which then in matrix form gives: [latex]\begin{pmatrix} Ra+\frac{1}{C} & -\frac{1}{C} \\Ra & La^2\end{pmatrix}\begin{pmatrix}q_{1}\\q_{2}\end{pmatrix}=\begin{pmatri x}0\\0\end{pmatrix}[/latex] Setting the determinant of the matrix equal to zero, leads to a cubic. There is going to be a constant term corrisponding to the solution a=0, and the remaining quadratic gives a repeated root (using the values of L,C,R given): [latex]a=-\frac{1}{2RC}[/latex]. For this value of a we get a solution: [latex]\begin{pmatrix}Q_{1}\\Q_{2}\end{pmatrix}=A \begin{pmatrix}2\\1\end{pmatrix} exp(\frac{-t}{2RC})[/latex] where A is an arbitary constant. But now I need to find another solution. I think it'll be of the form [latex](Bt+C)exp(\frac{-t}{2RC})[/latex] where B is related to A but I'm not sure how to go about finding it? Most of the results google gives seem to be for a slightly different style of question where there is only one first order derivative in each equation. Thanks in advance. |
| Apr9-07, 06:23 AM | #2 |
[tex]RQ_1+ L\frac{dQ_2}{dt}= C_1[/tex] so [tex]Q_1= \frac{C_1}{R}-\frac{L}{R} \frac{Q_2}{dt}[/tex] Also from the second equation, [tex]R\frac{dQ_1}{dt}= -L\frac{d^2Q_2}{dt^2}[/tex] so we can replace both instances of Q1 in the first equation: [tex]-L\frac{d^2Q_2}{dt^2}+\frac{1}{C}(\frac{C_1}{R}- \frac{L}{R}\frac{dQ_2}{dt}-Q2)= 0[/tex] or [tex]-L\frac{d^2Q_2}{dt^2}-\frac{L}{CR}\frac{dQ_2}{dt}- \frac{1}{C}Q_2= -\frac{C_1}{CR}[/itex] a second order non-homogeneous equation with constant coefficients. Since that is a second order differential equation, it will have two independent solutions involving two new constants. That's as it should be since you orginally had first and second order equations to solve. After you have solved for Q2(t) you can immediately get Q1 from [tex]Q_1= \frac{C_1}{R}-\frac{L}{R} \frac{Q_2}{dt}[/tex] |
| Apr9-07, 08:45 AM | #3 |
Thank you.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Coupled differential equations
| first order coupled differential equations | Differential Equations | 11 | ||
| Solving Coupled Differential Equations (in Matlab) | Math & Science Software | 0 | ||
| Eigenvalues of second order coupled differential equations | Differential Equations | 0 | ||
| Coupled first order differential equations | Differential Equations | 5 | ||
| Coupled first order differential equations | Differential Equations | 2 | ||
