Balsa Span Designs: Brainstorming Efficient Designs
  • Thread starter Thread starter SolomonKane
    Span
The discussion focuses on efficient design options for balsa wood spans, highlighting the inverted triangle and arch substructure as potential designs. Participants suggest exploring current bridge designs for inspiration, emphasizing the need for simplicity and efficiency given the limitations of materials such as balsa wood and glue. Additionally, the idea of buttressing with cement blocks on either side is proposed to enhance structural support. The conversation underscores the distinction between bridge design constraints and the more flexible requirements for balsa wood spans.
  • Understanding of structural engineering principles
  • Familiarity with balsa wood properties and limitations
  • Knowledge of bridge design concepts
  • Basic skills in model construction and design
  • Research efficient balsa wood span designs
  • Explore structural integrity principles in model building
  • Analyze current bridge designs for material efficiency
  • Investigate buttressing techniques for lightweight structures
Model builders, structural engineers, hobbyists interested in lightweight construction, and anyone looking to optimize designs using balsa wood.
SolomonKane
What do you think the most efficient designs are for a balsa wood span? I was considering an inverted triangle or arch substructure, but I am in the brainstorming process and need other options. In addition, I was considering an extra measure to support the span by buttressing the two cement blocks on either side.
Try looking at some current bridge designs. I imagine that they are very efficient, as bridge building material is expensive!
Considering that the materials are limited to the balsa wood and glue, current bridge designs are not necessarily the most simple or efficient. Also note that while bridges are restricted by the purpose of carrying a dynamic load on a deck, the span does not have this hindrance.
11K
9K
