Solve Momentum Problem: Skateboarder Mass m1=48kg Jumps 2.9kg Board at Rest
  • Thread starter Thread starter fishert16
    Momentum
The problem involves a skateboarder with a mass of 48 kg jumping onto a skateboard with a mass of 2.9 kg, which is initially at rest at the bottom of a curved ramp. The skateboarder runs at a speed of 6.8 m/s before the jump, and the goal is to determine how high they and the skateboard will go after the jump.
  • Participants discuss the application of energy conservation and momentum principles, questioning the initial conditions and assumptions regarding the skateboarder's speed upon landing.
Some participants have provided guidance on the use of momentum conservation and mechanical energy conservation. There is an ongoing exploration of the implications of the ramp's curvature and friction, as well as the initial speed of the skateboarder when landing on the skateboard.
Participants note the lack of information regarding the ramp's curvature and friction, which may affect the outcome. There is also a discussion about the initial speed of the skateboarder when landing on the skateboard, which has not been explicitly stated in the problem.
fishert16
A Skateboarder with mass m1=48kg runs at 6.8m/s and jumps onto her skateboard with mass m2=2.9kg which is at rest at the bottom of a curved ramp. When the skateboarder lands on the board, how high does she and the skateboard go?
Relevant equations
w=[1/2(MVf^s)-1/2(MVi^2)]+[(MGHf-MGHi)]
The attempt at a solution
[(1/2(50.9)(0)^2)-(1/2(50.9)(6.8)^2)]+[(50.9)(9.8)(x)-(50.9)(9.8)(0)]
I found this to work out to
(0-1176.81)+(498.82x-0)
x=2.36m
I have worked out his equation and found Hf to be 2.36m I am just not sure if this is correct or if not could someone enlighten me on another equation or where i went wrong thanks.
It would be better if you could show your work. You may get the right answer using wrong method, too.
There must be more to this problem. For example, how curved is the ramp? What about friction between the board and the ramp? Does the skateboarder jump onto her skateboard with the same running speed?
I have edited to show the work and give a better view to show what i have done.
x=2.36m
Where is it stated in problem that the person and the skateboard move at 6.8 m/s? You have titled this thread "Momentum problem," but it seems you have not considered momentum at all!
Well that does not help me determine how to fix this problem. Should the velocity used in the problem be found from (MV1+MV2) = M(1+2)V(1+2) and solve for V1+2?
Yes, that's right.
so i found that to be 6.4m/s and i would plug this into where i intially had 6.8 and this should yield the correct answer
Yep. All that you are using is conservation of linear momentum in the first case, and the conservation of mechanical energy to the find the height.
Thanks for the help
  • · Replies 25 ·
12K
