How Is Work Calculated with a Variable Force?
The discussion revolves around calculating work done by a variable force acting on a 3kg object moving along the x-axis. The problem includes multiple parts, such as finding work done over specific intervals, kinetic energy at certain points, and speed calculations, while considering the nature of the force as it varies with position.
  • Participants discuss the relationship between work and the area under the force versus position curve, with some questioning how to apply integration given the variable nature of the force. Others explore the implications of negative force values and how they affect energy calculations.
Participants are actively engaging with the problem, raising questions about the correct application of equations and the implications of variable forces. Some have suggested breaking the problem into simpler geometric shapes for area calculation, while others are clarifying the relationship between work and kinetic energy. There is no explicit consensus on the methods being discussed.
Participants note the absence of a graph for the force versus position relationship, which is crucial for accurate calculations. Additionally, there is confusion regarding the application of certain equations under non-constant acceleration conditions.
cristina
A 3kg object moving along the x-axis has a velocity of 2.40m/s as it passes through the origin. It is acted on by a single force Fx that varies with x as shown...
a) find the work done by the force from x=0 to x = 2m
b) what is the kinetic energy of the object at x=2m?
c) what is the speed of the object at x=2m?
d) find the work done on the object from x=0 to x=4
e) what is the speed of the object at x =4m
a) I know since the force is variable the work is equal to the area under the curve Fx-versus-x. I don't know which value of F should I put in the Work integral equation S fx dx.
b) k = 1/2mv^2 =1/2(3kg)v^2
the force on the curve at x=2 is F = 1.9N can I put it the Newton second law equation Ftotal = ma, 1.9N = 3kg x a ,
a = 1.9N/3kg = 0.63 m/s^2 and then since I got the acceleration I pluge it in v^2 = v + 2(a)(dleta x) = (2.40m/s)+2(0.63)(2m-0m)= 4.92
so v = 2.22m/s ?
d) before x=4m actually at x = 3m the curve go under the x-axis
I will integrate the part from x=0 to x=3 and then subtract from it the integration from x=3 to x = 4. but again I don't know what force should I use in the work integration fromula.
I thank you in advance of your help.
Well, without the graph of F vs. x, we're not going to be able to give you anything but general statements.
[tex]W = \int_{x_i}^{x_f} F(x) \,dx[/tex]
which can be interpreted as the area under the curve of a graph of F vs. x. You're correct in that. If you have an equation for F(x), then you're going to put that the integral and evaluate the indefinite integral between the initial x point and the final x point, which are 0 and 2m respectively for part (a).
For (b), you're working way too hard. Work is the change in energy. You're to assume that all of the energy gained (or lost) by the applied force is transformed into (or taken away from) the kinetic energy. So all you have to do is calculate the kinetic energy at the origin and then add the work done between 0 and 2m (which you did in part (a)!).
(c) Work backwards using part (b).
(d) Same as part (a), except the inital point is 0 and the final point is 4m. If you want, you can split up the integral into two separates ones, one between 0 and 2m and the other between 2m and 4m, and use part (a).
(e) As part (c).
Hope this helps. If it's still giving you trouble, we'll be able to help more if you can give us a picture of the graph or at least describe it.
cookiemonster
Is the speed wrong in c)?
so v = 2.22m/s
I don't have an equation, If I had I would differentiat it as you said. all I have it a graph.
The problem with your approach is that the acceleration is not constant if the force is not constant, as in this case. The equation you used is valid only for constant acceleration (i.e. constant force).
As for finding the area under the curve, I can't really help you because I don't know what it looks like. If you're in high school, then I imagine you'll be able to figure it out by breaking it up into triangles and rectangles and using a bit of geometry, but who knows.
cookiemonster
I will break it into rectangles and triangles, this is a great idea actually. but I thought I can get the Force values and integrate it but force is not constant as you said. May I please ask you about the cirve at x = 3m the curve go under the x-axis so force is negative can I calculate the area of the from x=3 to x=4 and then subtact it from x=0 to x = 3 so I would have the calculated the work done on the object from x= 0 to x = 4, is it right the way I am thinking?
May you explain more on how to get the speed please?
When force is negative, then you're taking energy out of the system (not generally true, but it is in this case). Consequently, the change in energy (work) will be negative, so you'll just subtract the area below the curve from the area above the curve to get the total work.
As for the speed, calculate the kinetic energy at x = 0. The velocity at x = 0 is given. Now, the work is the change in energy. So if the energy started at the value you just calculated, then at x = 2m, it will be different by the amount of work done between x = 0 and x = 2m. Consequently, you can just add the work done to the original energy to get the energy at that point. Once you know the energy, you can calculate the velocity using E = 1/2mv^2.
cookiemonster
so v = 2.22m/s ?
Just a sidenote, that equation is wrong. It's:
[tex]{v_f}^2 = {v_0}^2 + 2a\Delta x[/tex]
(Remember you are not supposed to use that equation here, I am just correcting it.)
