Uncovering the Mystery of an Infinite Nail
  • Context: Undergrad
  • Thread starter Thread starter KingNothing
    Infinite Mystery
The discussion revolves around a physics problem involving a hammer striking a nail, where the distance the nail penetrates decreases with each strike, forming a geometric sequence. Participants explore the implications of this sequence, particularly regarding the total distance the nail will penetrate after an infinite number of strikes, touching on concepts of convergence and limits.
  • One participant argues that since the nail goes further with each strike, it could theoretically go infinitely far.
  • Another participant suggests that if the nail's penetration follows a geometric sequence, it will converge to a finite limit, specifically questioning the limit of a related expression.
  • Some participants discuss the sum of a geometric series, noting that it converges to a finite value rather than infinity.
  • There is a mention of the time taken to sum the series, with one participant humorously reflecting on the speed of summation.
  • Another participant expresses confusion about the convergence of the series and the asymptotic behavior of the total distance.
  • Mathematical expressions are provided to illustrate the convergence of the series, with a specific calculation yielding a total distance of 6.4 cm.
  • One participant confirms that the calculated total distance represents a horizontal asymptote for the total penetration of the nail.
Participants express differing views on whether the nail will penetrate infinitely or converge to a finite distance. While some support the idea of convergence to a specific value, others maintain that the nail could go infinitely far, leading to an unresolved debate.
Participants reference mathematical concepts such as limits and geometric series, but there are unresolved aspects regarding the assumptions made about the physical scenario and the implications of the geometric sequence.
KingNothing
This came about on a test today (we have handed it in) and it just got to me. I didn't think it was hard until my teacher made an outrageous claim. Here goes nothin:
A hammer strikes a nail, and the nail goes in .8 cm. On the second strike, it will go in .7 cm. It is a geometric sequence. How far will the nail go in an infinite amount of hammer strikes?
Now, I said infinitely far. My teacher said that we should assume the nail could keep going even after it's flush with the wood. He also declared that there was an exact and real number that it would be (the answer). He compared it to the example he used earlier in the year: "I am walking towards that door. I will go halfway there each time. I won't ever reach the door."
Now, I don't think that really applies here. My reasoning for saying 'infinitely far' is that each time, it goes further, therefore in infinitely many strike, it will go infinitely far.
If it's going .1cm in each hit, then it will go infinitely far. On the other hand, if how far the nail goes in each time is a geometric sequence as you said, then it will only go in 1/8 whatever's left, i.e. 7/8 as much will be exposed after the hit each time.
So the question becomes, what's
[tex]\lim_{n\to \infty} 8\cdot\Big(\frac{7}{8}\Big)^n[/tex]
cookiemonster
I add up the numbers 1, 1/2, 1/4, 1/8 etc. I add up an infinite number of them, the answer isn't infinity.
But how long will it take you to add them all up??
I do the first sum in a second, the second in half a second, the third in an eighth of a second. Time flies when you're having fun. Of course, if I well order a subset of time of ordinal type w^2 I can do an infinite number of infinite sums. I hope no one is taking this seriously.
Right, in fact, it's whatever the last term is less than 2, right? You'd just have...let me see..
8, 7, 49/8, 343/64...hmm, I dunno. I guess I just don't see where the asymptote is. Is it zero? Then I end up with an asymptote, and an area I'd like to calculate the are of (i think, to sum the terms), but the area looks infinite to me. I know it's not, of course..maybe I just have trouble with 7/8 more because it's less than half.
anyhow, I'm still not sure what the answer is, because I haven't used the calculation that cookiemonster dipsplayed before.
edit: and before you go on, trust me, i understand how the "1/2 more each time" thing works...it's this 7/8 total that's giving me trouble.
Wow, shoot me now. I just totally misread that question. 2 in a day.
cryingmonster
At first the nail goes in 0.8cm. In the second hit it goes in 0.7cm, which is 7/8 of the previous distance. Whenever you have a geometric series in which the ratio is smaller than 1 and bigger than -1, it converges and its sum is:
[tex]S = a\frac {1}{1 - r}[/tex]
This is because:
[tex]S_n = a\frac {1 - r^{n+1}}{1 - r}[/tex]
But [tex]n \rightarrow \infty[/tex] and |r| < 1, and any fraction to the power of infinity is 0.
A geometric series is one that goes
a+ar+ar^2+a^r3+...
a is the first term r is the common ratio.
Let S(n) be the sum up to the term ar^{n-1}, the sum of the first n terms.
What is rS(n)? It's ar+ar^2+..+ar^n
so S(n)(r-1)=ar^n-a
S(n) = a(r^n-1)/(r-1)
Now let n tend to infinity. If r is less than 1 in absolute value then the sum converges to a/(1-r)
Here the first term, a, is 0.8, and the ratio is 0.7/0.8 = 7/8
so the nail travels
(8/10)(1/(1-7/8)) = 64/10 or 6.4cm as we've been given decimals
Thank you, Matt! Just to be clear: 6.4 will be an asymptote of the total distance, right?
Yes, it will be a horizontal asymptote.
  • · Replies 23 ·
12K
  • · Replies 26 ·
