Thread Closed
Convergent sequence of functions?
Share Thread Thread Tools
Apr12-07, 01:02 AM   #1
How do you show a sequence of functions in terms of n is convergent (in general)?
3. The attempt at a solution
Do you presuppose the value of the function say v then show d(fn,v)->0 for n large?
v is determined by looking at the sequence of functions and guessing what they may be approaching.
Is there an easier way?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr12-07, 02:33 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
I assume you're asking this purely out of curiosity so I'll just give the fact and not much of the details. If you want a more serious answer, just pick any real analysis book.
There are two types or "notions" of convergence that we can be interested in here: pointwise and uniform.
In pointwise, we fix x to say x0 and we look at the resulting numerical sequence {f_n(x0)}. This is a sequence like you know them. You can either guess the value to which it converge and prove that you're right with epsilon & N. Or, if you're only interested in knowing whether or not the sequence converge and not to its actual limit value is, you can try to find out whether or not the sequence is Cauchy.
In uniform, we wonder if there is a function f(x) to which the sequence {f_n(x)} converges pointwise for all values of x in some set, and does so "essentially as fast" at all points. A little more technically speaking, given an epsilon, we ask that there is an N such that FOR ALL x in the set, |f_n(x)-f(x)|<epsilon as soon as n>N. There is also a Cauchy criterion for uniform convergence and other criteria as well.
Apr12-07, 05:54 AM   #3
So all uniformly convergent functions are pointwise convergent?
There is a function with a max value in the limit that is non zero but the function as a whole for all x in the domain converges to f(x)=0. What do you make of that?
Does it mean its pointwise convergent since the max value occurs at the end of the domain.
Apr12-07, 06:26 AM   #4
Recognitions:
Quote by pivoxa15 View Post
yes
that sentence doesn't make sense. A function cannot converge. A sequence converges. So let's say we have a sequence of functions f_n. Now you hav just said it converges without specifying which kind of convergence which means that
doesn't make sense.
So, you're claiming to have a sequence f_n(x) that pointwise converges to f(x) which is the zero function.
Now, what does 'a function with a max value in the limit that is non-zero' mean?
Do you meant that that if we set S_n to be the sup(f_n(x)), then S_n does not converge to zero?
Certainly there are functions like that.
Apr12-07, 05:17 PM   #5
Quote by matt grime View Post
Yes that is what I mean. The thing is the non zero max value is in the domain of the function. i.e S_n(x) is non zero with x in the domain.
That is very unintutive. The whole sequence for every x goes to 0. i.e f_n converges to 0, however.
Apr13-07, 03:31 AM   #6
Recognitions:
First, the 'non-zero max value' is not in the domain of the function. Second, the maximal value need not exist: sup is not max. It is the Sup that you want to think about. Whether the function attains the sup is immaterial, and possibly causing you confusion.
The standard examples look something like this:
let f_n=x^n on the interval (0,1).
The Sup of f_n is 1 for all n (though it doesn't attain that value anywhere on the domain).
The pointwise limit is the zero function.
This is not the uniform limit. It does not converge in the uniform metric.
Apr13-07, 03:38 AM   #7
Why isn't the 'non-zero max value' not in the domain of the function? It could be? i.e function is defined on [0,1] and max x occurs when x = n/(n+1) so for large n the non zero max value is certainly in this interval.
Apr13-07, 04:18 AM   #8
It can't be in the domain of the limit function; otherwise the limit function would have to share the discrepancy. Other examples abound.
For example, for each n>0 take [itex]f_n(x) = ne^{-(x-n)^2}[/itex] on the reals. Then for every [itex]x \in \mathbb{R}[/itex] the sequence [itex](f_n(x))_{n=1}^\infty[/itex] converges pointwise to 0, but the sequence of functions doesn't converge uniformly on, say, [itex](0, \infty)[/itex].
Here [itex]f_n(n)[/itex] is always n; Thus the "nonzero max value" is actually going to infinity with n. Simultaneously, increasing n moves the "bump" farther out, resulting in the pointwise convergence. It's always there, so the sequence of functions can't converge uniformly.
Apr13-07, 03:05 PM   #9
Recognitions:
*If* a function attains its sup, then the value of the sup is in *range*, for pete's sake, not the bloody domain.
Apr13-07, 03:08 PM   #10
Recognitions:
No, the point at which it attains its maximum is in the domain (and is for all positive n in this fictitious example, I don't know why you think it is for 'large n'). The value of the maximum is whatever f(n/(1+1)) is, and is not in the domain.
Apr13-07, 03:46 PM   #11
"The point at which it attains its maximum is in the domain." is what I am trying to say. The fact that the maximum which is in the range is non zero in the limit suggest f dosen't converge to 0 for all x in the domain. But some f do and with a point in the domian where it attains a non zero maximum in the limit.
Apr14-07, 03:26 AM   #12
Recognitions:
I'm very confused by what you're talking about. You keep talking about *the* maximum as if there is only one maximal value at play here. Surely you mean on for each f_n. f is a function. f does not converge. I repeat: a sequence converges (or diverges). A function does not.
Stop writing f when you mean a sequence f_n, and be clearer with what has a maximum (or sup for preference). And if you're going to say converge, at least indicate in what sense you mean converge - L_1, L_2, ..., L_infinity etc. (Pointwise or uniform would be a start.)
Actually, is there a question here any more?
Apr16-07, 05:27 AM   #13
My question is
f_n converges pointwise to 0 for all x in [0,1] but there exists a non zero sup in the limit in the range of f_n. How can that be?
Is this possible because this condition would imply that f_n always gets lowered but not neccessary reaching 0 and the sup always gets shifted towards the right or left so that as n increase f_n is lower than f_n for smaller n, for all x in the domain. So it doesn't mean f_n will reach the 0 value for all x hence sup f_n can still be nonzero in the lmit.
Apr16-07, 02:58 PM   #14
Recognitions:
It can't happen. If f, the pointwise limit is 0, then sup(f(x))=0. f is identically zero.
I am assuming that sup lim (f_n) is what you meant by the phrase:
It is certainly true that if f_n converges pointwise to f, that the two quantities
lim sup(f_n)
and
sup lim (f_n)
need not be equal. Though not in the case that the domain of f is compact.
Apr16-07, 04:24 PM   #15
Take f_n(x)=nx^n(1-x) for x in [0,1]
sup lim (f_n)=1/e
but f_n converges pointwise for all x in the domain to 0
Apr16-07, 04:34 PM   #16
Recognitions:
Hold on. You've got things the wrong way round.
sup lim f_n
is zero, since lim f_n is the zero function (taking the limit pointwise).
You mean
lim sup f_n =1/e,
but why would expect sups to commute with pointwise limits?
Apr16-07, 06:23 PM   #17
lim sup(f_n)
and
sup lim (f_n)
So in this case lim sup(f_n) does not equal sup lim (f_n) but the domain is compact?
It is not very intuitive but maybe one can think of it as the sup(f_n) as n increase keep shifting to the right or left so at each x, f_n(x) converges pointwise to 0 but some points will never ever reach it as lim sup(f_n) is non zero.
Thread Closed
Thread Tools
Similar Threads for: Convergent sequence of functions?
Thread Forum Replies
uniformly convergent sequence Calculus 1
Bounded sequence implies convergent subsequence Calculus & Beyond Homework 1
bounded sequence as convergent General Math 7
convergent sequence? Set Theory, Logic, Probability, Statistics 1
all about sequence of functions Calculus & Beyond Homework 2
