Find the work done on the block by the spring
The problem involves a 5kg block interacting with a spring of force constant 20N/cm, compressed by 3cm. The discussion focuses on calculating the work done by the spring as it extends, the energy dissipated by friction, the speed of the block at the equilibrium position, and the distance the block would slide if detached from the spring.
  • Mixed
  • Participants discuss the work done by the spring and the role of friction in energy dissipation. Questions arise regarding the appropriate formulas for calculating work and energy, particularly in relation to constant and variable forces. Some participants express confusion about the concepts of work systems and the necessity of considering friction.
There is an ongoing exploration of different approaches to the problem, with some participants offering guidance on relevant formulas and concepts. However, there is no explicit consensus on the methods to be used, and various interpretations of the problem are being considered.
Participants note the importance of understanding the effects of friction and the definitions of work in the context of the problem. There is also mention of potential confusion regarding the application of specific formulas and the assumptions underlying the problem setup.
cristina
A 5kg block is held against a spring of force constant 20N/cm, compressing it 3cm. The block is released and the spring extends, pushing the block along a horizontal surface. The coefficient of friction between the surface and the block is 0.2.
a) Find the work done on the block by the spring as it extends from its compression to its equilibrium position.
b) Find the energy dissipated by friction while the block moves the 3cm to the equilibrium position of the string.
c) What is the speed of the block when the spring is at its equilibrium position?
d) If the block is not attached to the spring, now far will it slide along the surface before coming to rest?
If you are not able to do anything with these problems then you have much worse problems than we can do anything about! At least, show us what you have tried so we will know how to help you.
Do you know any formula for work done by a spring?
This is easier than a) because the force is a constant. How do you find the work done by a constant force moving an object 3 cm? Do you know how to find the friction force given the "coefficient of friction"?
One way to do this (the hard way!) is to calculate the total force (spring force and friction force) at each instant, use that to calculate the speed and position as functions of time, solve for the time that the block is at the equilibrium position and use that to find the speed of the block.
Much simpler is to find the potential energy in the compressed spring (if this isn't a calculus course, you have a formula for that). You calculated the work done by friction on the block in (b). Subtract that from the potential energy you just found. The rest is converted into kinetic energy:(1/2)mv2.
As you may see that I am still working on the previous ones and I did post my work. I am really lost in the concept of the work systems.
should I take friction into concideration on b?
can I use mgh=1/2k(x^2)? I am really lost with this one.
"should I take friction into concideration on b? "
Now that's a very strange question! (b) says "Find the energy dissipated by friction". Yes, you have to take friction into consideration in order to find the energy dissipated by friction!
"Work" is "force times distance" for a constant force and, for a variable force, f(x), becomes integral of f(x) dx. In the case of a spring with spring constant 20 N/cm, f(x)= -20 x.
[tex]\int_0^3 -20xdx= (-10)x^2\|_0^3= -90 Joules[/tex].
(That's your formula "mgh=1/2k(x^2)" although "work" is not always "mgh"- that's the work done in lifting something a height h and there is no height in this problem). That's the work done in compressing the spring 3 cm and so the work done on the block by the spring as it "uncompresses" is 90 Joules.
The block has mass 50kg and so weight 50g N. The coefficient of friction is 0.2 so the friction force is (0.2)(50g)= 25g N. The work done moving the block .03 m is (0.03)(25g)= 0.75g or approximately 7.35 J.
Since 7.35 J goes into pushing against friction, the rest of the work, 90- 7.35= 82.65 J changes into kinetic energy. The kinetic energy of the block is (1/2)mv2= 45v2= 82.65 so v2= 1.84 and v= 1.36 m/s at the equilibrium point. ("20 N/cm" is one heck of a strong spring!)
If the block is not attatched to the spring, then once it has passed the equilibrium point, the spring no longer acts on it. Past that point the only force is the 25g= 245.25 N friction force. The total energy of the block at the equilibrium point is 82.65 J and the work done by the friction stopping the block must equal that. Letting x be the distance past the equilibrium point the block slides, 245.25x= 82.65 so x= 82.65/245.25= 0.35 m or 34 cm.
  • · Replies 18 ·
  • · Replies 27 ·
11K
  • · Replies 58 ·
