Understanding the Cauchy Problem with the Picard Theorem
  • Context: Graduate
  • Thread starter Thread starter JasonRox
    Theorem
The discussion revolves around the Cauchy problem and the Picard theorem, focusing on their definitions, implications, and applications in solving initial value problems in differential equations. Participants explore the concepts theoretically and through examples, including Picard iterations and the conditions under which solutions exist and are unique.
  • Homework-related
  • One participant seeks clarification on the definitions of the Cauchy problem and the Picard theorem, indicating difficulty in finding information in textbooks.
  • Another participant provides a definition of the Cauchy problem as an initial value problem and explains the Picard theorem regarding the existence and uniqueness of solutions under certain conditions.
  • Discussion includes the concept of Lipschitz continuity and its significance in determining the uniqueness of solutions to differential equations.
  • Participants discuss the process of Picard iterations, detailing how to construct a sequence of functions that converge to the solution of an initial value problem.
  • One participant raises a question about the existence and uniqueness of solutions for specific differential equations, referencing the Cauchy-Lipschitz-Picard theorem.
  • Another participant provides an example of a function that is continuous but not Lipschitz, illustrating the potential for multiple solutions to exist.
Participants generally agree on the definitions and implications of the Cauchy problem and the Picard theorem, but there are unresolved questions regarding specific examples and the conditions for uniqueness of solutions. Some participants express uncertainty about applying theorems to particular cases.
Limitations include the dependence on the definitions of Lipschitz continuity and continuity, as well as the unresolved nature of specific examples presented by participants. The discussion does not reach a consensus on the uniqueness of solutions for the provided examples.
JasonRox
What are they? I can't find it on the internet or in my two different textbooks. It's not anywhere in the index.
Also, what is the Cauchy problem?
Statement of the Picard Theorem on the existence and uniqueness of solution for the Cauchy problem x’ = f(t,x), x(t0) = x0 in case f(t,x) is continuous and Lipschitz in x.
That's from our review. I don't know what the Picard Theorem is (I think I know what it is just by reading the above.), but most importantly what is the Cauchy Problem?
Thanks.
The 'Cauchy problem' is exactly what you give: the "initial value" problem: Solve x'(t)= f(t,x) with the condition x(t0)= x0.
Picard's theorem is what you probably guessed:
Given any point in the plane, (x0, y0), and a function f(x,y), continuous on some neighborhood of (x0, y0) and Lipschitz in y on that neighborhood, then there exist a unique function y(x) satisfying y'= f(x,y) and y(x0)= y0.
A "neighborhood" of a point is an open set containing that point.
A function, f(x), is "Lipschitz" on a set if and only if there exist a positive number C such that for any x, y in that set, |f(x)-f(y)|< C|x-y|.
It's easy to see that if f(x) is Lipschitz on a set then it is continuous at every point of that set. You can use the mean value theorem to show that if a function is differentiable at every point of a set, then it is Lipschitz on the set (notice that, while "continuous" and "differentiable" are defined at points, Lipschitz is defined on a set). Many introductory differential equations texts say "differentiable with respect to y at every point of the set" which is "sufficient" (since that function must be Lipschitz) but not necessary since there exist functions that are Lipschitz on a set but not differentiable.
If f(x,y) is continuous but not Lipschitz on a set, then there may be many functions satisfying the differential equation and "initial condition". For example, f(x,y)= y1/3 is continuous on any neighborhood of (0,0) but is not Lipschitz on such a neighborhood. dy/dx= y1/3 can be integrated as y-1/3dy= dx so
(3/2)y2/3= x+ C so y(x)= (2/3)(x+ C)3/2. Taking C= 0, y(x)= (2/3)x3/2 satisfies that equation as well as y(0)= 0. But y(x)= 0 for all x also obviously satisfies that equation as well as y(0)= 0. In fact, given any a, y(x)= (2/3)(x-a)3/2 satisfies that equation as well as y(a)= 0. Taking any negative number b, the function defined as y(x)= (2/3)(x-b)3/2 if x< b, y(x), y(x)= 0 if b< x< a, y(x)= (2/3)(x-a)3/2 satisfies the differential equation (even at x=b and x= a) and y(0)= 0.
Thanks a lot. I appreciate it.
It's what I guessed for the Picard's theorem. Now, I got the Cauchy problem out of the way too.
Another question...
Picard Iterations: general formula and running a couple of iterations.
What is that?
Picard's method for solving an initial value problem really formed the basis for his proof.
Given dx/dt= f(x,t), x(t0)= X0
for a sequence as follows.
x0(t)= X0 (i.e. is a constant function)
Solve dx/dt= f(X0,t) by integrating to get x1(t) (choosing the constant of integration so that x1(t0)= X0)
Now solve dx/dt= f(x1(t),t) by integrating. Iterate, getting a sequence of functions {xn(t)} that, if it converges, converges to the solution to the initial value problem.
For example, suppose the differential equation is dx/dt= x, x(0)= 1.
1) Solve dx/dt= 1, x(0)= 1: Integrating, x(t)= t+ C and x(0)= C= 1 so
x(t)= t+ 1.
2) Solve dx/dt= t+ 1, x(0)= 1: Integrating, x(t)= (1/2)t2+ t+ C and x(0)= C= 1 so x(t)= (1/2)t^2+ t+ 1.
3) Solve dx/dt= (1/2)t^2+ t+ 1, x(0)= 1: Integrating, x(t)= (1/6)t^3+ (1/2)t+ t+ C and x(0)= C= 1 so x(t)= (1/6)t^3+ (1/2)t^2+ t+ 1.
You see what's happening: with each iteration we get one more term in the Taylor's series for ex which is, of course, the solution to this problem.
This mimics the sequence method used in Picard's proof of his theorem.
its a limit process for finding successively better approximatiions to a solkution by iterating.
Hi,
sorry about bringing an old post up, but i need help about this example. I've an exam this monday and I looked at last years', there were some questions about Cauchy-Lipschitz-Picard theorem with this example. Question 1 is:
Using "Existence and Uniqueness" theorem, is it possible to show that the problem y' = y1/5 , y(0) = 0 has only one solution?
Question 2 is the same but the function is:
f(x,y) is defined,
(4x2y)/(x4 + y2), (x,y) is not (0,0)
0, (x,y) = (0,0)y' = f(x,y)
y(0) = 0
Since f(x,y) is continuous and differentiable, and it's derivative is continuous, I couldn't figure out how to show ||f(x, y1) - f(x, y2)|| <= N ||y1-y2|| (as it seems from the quote, first one is cannot be written like this?)
I'm sorry if i did sth wrong, but I don't have much time, so I just asked it here.
Thanks
  • · Replies 0 ·
  • · Replies 0 ·
