Uniform Charge Density: Homework Solution
  • Thread starter Thread starter sister007
    Charge Uniform
The discussion focuses on calculating the electric field strength between two large sheets of plastic with uniform surface charge densities of eta_1 = -eta_0 and eta_2 = +3eta_0. The electric field strengths at three points are analyzed: Point 1 (to the left of the negative plate), Point 2 (between the plates), and Point 3 (to the right of the positive plate). The correct approach involves using the formula for the electric field of a plane sheet, E = sigma/(2ε), leading to the conclusion that the net electric field at Point 1 is zero, while Point 2 and Point 3 require further calculations based on the superposition principle of electric fields.
  • Understanding of electric fields and charge distributions
  • Familiarity with the concept of superposition in electrostatics
  • Knowledge of the formula for electric field due to a plane sheet: E = sigma/(2ε)
  • Basic principles of capacitors and their electric field behavior
  • Study the superposition principle in electrostatics
  • Learn about electric field calculations for non-parallel plate configurations
  • Explore the concept of electric field lines and their representation
  • Review the properties of capacitors, particularly parallel plate capacitors
Students studying electrostatics, physics educators, and anyone interested in understanding electric fields generated by charged surfaces.
sister007
ou've hung two very large sheets of plastic facing each other with distance d between them, as shown in the figure View Figure . By rubbing them with wool and silk, you've managed to give one sheet a uniform surface charge density eta_1= - \eta _{0} and the other a uniform surface charge density eta_2= + 3 \eta _{0} . What is the electric field strength at
POINT 1 (TO THE LEFT OF THE NEGATIVE PLATE)
POINT 2 (BETWEEN THE PLATES)
POINT 3 (TO THE RIGHT OF THE POSITIVE PLATE)
Specific distances are not given, all the the distances ("radius's") from the plates are the same.
I was under the impression that only parrallel plate capacitors have uniform charge. So indeed all the charges will be different.
Would the point 1 be Net charge=o? Or would it be 1(nu)-3(nu)=-2nu?
Im my book it says Efield of plane= N/(2xEpsilon) Using that info, I said point 2 is equal to 3/2 (n/E). I was wrong, SO obviously I don't know what I am doing. Help.
There's no figure.
-1-(+3)=-4.
  • · Replies 26 ·
