Understanding Energy Conservation and its Impact on Everyday Life
The discussion revolves around the concept of energy conservation, particularly in relation to everyday phenomena such as human movement and car dynamics. Participants explore how energy transforms from one form to another, the implications of energy loss, and the challenges in calculating energy transformations in practical scenarios.
  • Some participants question whether energy can be destroyed, particularly in the context of human activity and car mechanics.
  • There is a discussion about the transformation of chemical energy from oil into kinetic energy and the subsequent loss of energy to heat, sound, and friction.
  • One participant suggests that the energy lost due to friction is difficult to recover, implying that it may require additional energy to collect it.
  • Another participant raises the question of whether kinetic energy can be transformed back into kinetic energy after being converted to heat.
  • There is a proposal that during a car crash, energy seems to disappear, leading to a discussion about the nature of energy and momentum in collisions.
  • Some participants clarify the distinction between energy and momentum, noting that energy is a scalar while momentum is a vector.
  • There are multiple analogies used, including a tug-of-war scenario, to illustrate the concepts of force, energy, and momentum.
Participants express varying views on the nature of energy transformation and loss, with no consensus reached on whether energy can be considered destroyed or how it is accounted for in different scenarios. The discussion remains unresolved regarding the complexities of energy and momentum interactions.
Participants exhibit confusion regarding the definitions and relationships between force, kinetic energy, and momentum, which may lead to misunderstandings in their arguments. The discussion also highlights the challenges in calculating energy transformations in practical applications.
expscv
it says that "energy can not be create or destroyed but from one form to another"
is this work for human? since we eat and use the chemical energy in the muscle to do work = running = kinetic energy but where is kenetic energy transfer to?
can anyone anlyse the energy in a car? oil ===> kinetic energy ===> heat and sound?
but the input and output of energy does not seems to balance.
energy seems to be destroyed
thanks
Sounds like homework --- but, it's the concepts that are giving you trouble, so post a little more on what makes you think energy is "being destroyed."
asd
the chemical energy of oil is transform to kinetic energy
but kinetic energe is not trasform to any other form.
it is been destroyed?
Most of it is lost to friction, sound, and heat.
cookiemonster
umm sounds right
but is fiction a type of energy?
Originally posted by expscv
umm sounds right
No, friction is a force which combined with motion and time gives energy. And energy = heat.
Friction in your car, working muscles, whatever: one way or another, it all ends up as heat.
yes but the problem ---> can the amount of heat been produced by kinetic energy
be transform into kinetic energy again? exactly as before?
it seems not possible.
It's very difficult to collect energy lost due to friction. In fact, if you managed to pull it off, you'd be an extremely rich man.
cookiemonster
Collecting the "wasted" energy back would probably require an investment of additional energy, anyway. :smile:
haha thanks never mind about rich
so: the conservation of energy must be true and that the amount of energy you used or applied somehow trasfer to other
so that kietic energy can trans to many other form like
light heat sound chemical, but how do i calculate the
magnitude?
i only know how to calculate potential to kinetic but not kinetic energy to any other.
It's most easily done by calculating the loss of energy.
For example, if you have a 2kg car that's rolling around at 10m/s at one point in time and then you measure it to be rolling around at 5 m/s a few seconds later, the difference in energy is
1(5^2 - 10^2) = -75J,
so 75J of energy went somewhere. The only real place it could have gone is heat/sound, so there you have it.
cookiemonster
:smile: oh i got it
now i m alive again haha thanks a lot
thx all!
i might be wrong but i think i have thought of another place the energy might go. back to the car slowing down 5km, its tires exert a force on the ground, pushing whatever is under it in the same direction of its movement, so the slight momentum of the car could be transferred to the momentum of the Earth itself. The Earth will never slow or speed up due to this though, because when the car sped up it also put energy going the other way, so it neutralizes the change. if you throw yourself into a wall, the Earth will spin faster, but you had to start running first and that already slowed the Earth down. of course the effects would be so minute that they could never be observed.
just a question. if one car going one way crashes into a car going the other way, what happens to the energy, they both stop, and the energy seems to be gone. mabye that's because the energy was opposite in the first place...
Originally posted by revesz
...you had to start running first and that already slowed the Earth down. of course the effects would be so minute that they could never be observed.
So if all people around the world starting running in the right direction together, we could stop Earth?
For starters, energy is a scalar and not a vector. Therefore the energy of one car can't be the "opposite" of the other car. There is nothing puzzling about this situation - when the cars crash you hear a big bang, don't you? And some heat develops, doesn't it? And the cars are suddenly reshaped, aren't they? That's just some some the processes that use up the original energy.
actually the energy is used in stopping the cars, one car exerts a force on the other car with enough force to stop the car, and vise versa, so each take the other cars energy to change their momentum. That makes perfect sense to me, but then what happened to the momentum?
momentum is relative, so it must be a vector, it is directional. If every particle of mass in the universe were moving the same way it would have no kinetic energy, it is only when something is moving the other way that there is momentum. Actually all things have momentum even when there still, they stay on their own place in space-time, which may or may not be moving relative to some other point in space-time, and they stay there until something else moves them, off that point in space-time. it is imposible to go from a stand still to moving north, without exerting a force south, it is impossible to be heading north and turn and go west without exerting a force east. That is because there is enough momentum going north to go west, but first you must accellerate in that direction. I don't remember what i was trying to get at now... o ya, momentum is scaler but it has three dimentions, the energy can be converted from one dimension to another. What i mean by dimension is left right, momentum, is different than front back momentum, and up down momentum. all are compatable with each other, exept for the opposite. which means that left doesn't cancel out up or down or front or back, but it does cancel out right. Left cancels right, up cancels down, front cancels back. It is true, think about two object heading toward each other. They don't give all their energy to heat and sound when the collide, they cancell out the others momentum, like tug-o-war
You seem to be confusing momentum with energy and vice versa. I will just point out that momentum is defined as [tex]m\vec v[/tex] and therefore it is a vector, not a scalar. A scalar cannot have three dimensions, and it cannot be exchanged between dimensions. If the two cars have the same mass and the same velocity but in different directions ([tex]\vec v_1 = - \vec v_2[/tex]), their momentums are also equal but in different directions ([tex]\vec P_1 = - \vec P_2[/tex]). However, their kinetic energy is exactly identical, since it defined as [tex]\frac{1}{2}mv^2[/tex], so the direction of the velocity doesn't matter at all. The two cars together have [tex]mv^2[/tex] kinetic energy, not zero.
But you are right that energy is "used" by each car to exert a force on the other to stop it. But force is not a form of energy, and the energy goes somewhere else. For example, when you push a crate across the floor, you exert a force on it, which gives the crate kinetic energy. The force itself is not the energy. Now if there is also friction between the crate and the floor, the crate's velocity will be smaller which means its kinetic energy is also smaller. The "missing" energy does not become a force, the friction, it becomes heat which is caused by the friction. See what I mean?
yes i think i am confused with what force, kinetic energy, momentum, and energy are. i sometimes use them interchangably. but there is still a problem that i will try and outline. a force pushing left will cancel out a force pushing right, so there will be no energy used. I was using the cars momentum as the pushing force. The kinetic energy stores the force. But i can put it into another analogy. two teams of very strong body builders are having a game of tog-o-war. They are exerting a force for 3 minutes, so they must be using enegy, but if the rope stays still, how can that be true? is it all converted into heat? how? there is no movement, so there can be no friction. but there is still a force, so there must be energy used. is this right, or is energy only used when work is accomplished?
now i will give another example of the car collision, but now it is two rockets in space. two rockets in space are facing opposite direction, and are accelerating away from each other. Attached to both the rockets is a rope, capabale of stopping both ships if they come to far apart. Now both ships hit the throttle and are soon going extremely fast in opposite directions, away from each other. When the rope stags them, they come to an instant halt, loosing all their momentum, not very much sound or heat would be made in this senario. How is the kinetic energy conserved?
Yes, the forces cancel each other so that the object experiences no acceleration and its velocity doesn't change (whether it's resting or not). Energy is still being wasted, of course. Could you stand a push a wall real hard, for hours and hours? Probably not, you would get tired. Why? Because you are spending energy... where that energy goes, you really should ask a biologist. But when you push the wall, your muscles do work even if the wall doesn't move one bit.
Some goes into bending the metal, the rest into heat (sound also dissipates as heat).
how about the tension of a rope? if you pull each end in opposite direction , energy is put in and eventually the rope will be break into two part.
and the energy you used could be from musicle or mechnic which is not trasform to any other form. energy is wasted? ...any biologist?
btw is the energy converted to the work being down?
am i confusing anyone?
The energy that the rope holds is potential energy, it's not "lost" (that's because the elastic force is preservative). When the rope tears, most of the potential energy is had becomes kinetic. Take a small rubber and pull it as much as you can... it will tear and snap at your fingers real fast. :wink:
cool you right potential energy that elastic force is preservative
would a metal spring get tired? no, is it exerting a force? yes.
its not actually doing anything, so it isn't using energy. It has only potential energy, and it keeps it until released from the wall.
Ok, say there was no friction at all, when the two ships snag the rope, and stop, where is the energy going? It can't all go into sound or heat, that would't be possible. do the ships bounce back when the rope gets tight, and keep their momentum? Mabye that's why a bouncy ball bounces, it can't convert all it's energy into heat and sound, so it keeps its kinetic energy and bounces off the other way.
If you push a metal spring towards a wall, you will get tired. If you stick a spring between two close walls, so that it is contracted, it doesn't actually do any work. Work is defined as [tex]W = F\Delta X\cos \theta[/tex], and while the spring does exert a force, neither the walls nor the spring move, so [tex]\Delta X = 0[/tex] and no work is done by the spring.
How this relates to the example of you pushing a wall, is beyond me though. Because when you push a wall, your hands don't appear to be moving so apparently the work you do is zero. But in fact your muscles move within your body, and their work is anything but zero or else you wouldn't get tired.
Isometric work = Force x Time
  • · Replies 21 ·
