Divergence Theorem - Confused :s (2 problems)
The discussion revolves around the application of the divergence theorem to a vector field over a circular region. Participants explore the evaluation of both sides of the theorem, addressing specific issues related to the normal vector and the line integral involved in the calculations.
  • One participant states the divergence theorem and attempts to evaluate both sides, noting a discrepancy in their calculations.
  • Another participant points out that the function f(x) = (1 - x^2)^(1/2) only represents the upper half of the circle, which may lead to confusion in determining the normal vector.
  • There is a discussion about the correct expression for d(sigma), with one participant asserting it should be R d(theta), while another initially disagrees.
  • A participant questions the use of the gradient of f(x,y) = x^2 + y^2 to find the normal vector, expressing uncertainty about how it relates to the circle of radius R.
  • Another participant suggests that finding a tangent vector to the circle and then deriving the normal vector from it is a more rigorous approach, while acknowledging that using the gradient is a simpler method.
  • One participant concludes that thinking of f(x,y) as a contour map with concentric circles helps in understanding the relationship between the gradient and the normal vector.
Participants express differing views on the correct approach to finding the normal vector and the interpretation of the divergence theorem in this context. There is no consensus on the best method, and some confusion remains regarding the mathematical details.
Participants note limitations in their understanding of the mathematical concepts involved, particularly regarding the representation of the circle and the application of the gradient in this scenario. There are unresolved questions about the relationship between the functions used and the geometric interpretation.
halfoflessthan5
Question
Evaluate both sides of the divergence theorem for
V =(x)i +(y)j
over a circle of radius R
Correct answer
The answer should be 2(pi)(R^2)
My Answer
the divergence theorem is
**integral** (V . n ) d(sigma) = **double intergral** DivV d(tau)
in 2D. Where (sigma) is the curve bounding the area (tau.) n is the unit normal vector to the curve.
I did the RHS of the divergence theorem fine and got 2(pi)(R^2)
For the LHS:
First I need to work out n, the unit normal vector to the circle.
The equation of the circle is y=(1 - (x^2)^1/2)
To get the unit normal you use the nabla (gradient) function to get a vector that points away from the line and then normalize it.
First problem: In the solution they took grad(x^2 + y^2.) You end up with n (normalised) as (x/R)i + (y/R)j. . But i don't understand why you take grad(x^2 + y^2) when the line has the function f(x)=(1 - (x^2)^1/2)
Pretending i understood that bit and moving on you get V.n = (x^2/R) + (y^2R) = R^2/R =R
So I need to work out *integral* R d(sigma)
i presume d(sigma) (the elemental boundary length) is d(theta.) Then you do the line integral from 0 to 2(pi) . R is a constant so you can take it out then you just get 2(pi) for the integral
=> *integral* (V.n) d(sigma) = 2(pi)R
which is wrong (missing an R)
Sorry for the length of that. Some help on those two problems would be awesome. :wink:
Well, the big problem with the first part you're having trouble with is that f(x) = (1 - x^2)^(1/2) only represents the top part of the circle.
The second problem is that d(sigma) isn't d(theta).
Yes! its R d(theta.) The length of the arc subtended. Which would provide the extra R. Excellent, thankyou :biggrin:
Okay point taken. I am not sure how else to write the function though. f(x) = +/-(1 - x^2)^(1/2) would give the top and the bottom but i can't do anything with that.
(just noticed something, that should be a an R not a 1. Doesnt affect anything)
Since in the solution you do grad(x^2 + y^2.) you must be taking grad f(x,y) where
f(x,y)= x^2 + y^2
but that's the equation of a 3D surface (i don't know what surface, its not a sphere.)
How does it represent my circle of radius R? (there's no R in it for a start)
Technically, what you should do is find a tangent vector for your circle, then get a vector perpendicular to that to find the normal. But, as far as I remember, taking the gradient is essentially a cheat.
Basically, what you're doing is saying that every level set of f(x,y) = x^2 + y^2 represents a circle of some radius. So what you do is find the outward normal of the surface (which is (fx, fy, -1), then project it into the plane (level set) where z = r^2, and that gives you the outward normal for the circle in that plane.
But don't quote me on that. I never got a really rigorous treatment of that kind of stuff because the few times it was covered in my classes, I was swamped with other work. I just used it if it worked.
okay got it. So i can think of f(x,y) as like a contour map with a load of concentric circles each representing a value of f(x,y.)
So you workout grad f(x,y) and normalize it then set (x^2 + y^2) to R^2... and it works!
thankyou for all the help mystic. Youre a legend
  • · Replies 29 ·
