Magnetic fields from power lines
The discussion focuses on the principles of electromagnetic induction related to power lines carrying alternating current (AC). To maximize voltage induction, the coil should be oriented perpendicularly to the power line, aligning it with the magnetic field. Additionally, placing the coil near a high current wire is preferable, as it generates a stronger magnetic field, thus inducing a higher voltage. Participants suggest incorporating numerical analysis and design considerations for the receiving coil to enhance understanding.
  • Understanding of electromagnetic induction principles
  • Familiarity with alternating current (AC) characteristics
  • Knowledge of coil design and orientation for maximum voltage induction
  • Basic grasp of Ohm's Law (V=IR)
  • Research the design parameters for receiving coils in electromagnetic induction
  • Explore the characteristics of typical high voltage and high current power lines
  • Learn about the effects of coil orientation on induced voltage
  • Investigate safety regulations and ethical considerations regarding electricity theft
Electrical engineering students, hobbyists interested in electromagnetic applications, and individuals studying the principles of induction related to power lines.
edosqclbe695
Well I just want to make sure I am right on this one. The question is how to steal electricity by placing a coil near a power line that carries alternating current in which the current varies sinusoidally. A.) For a single wire how should the coil be oriented to induce the maximum voltage. B.) And should the coil be placed near a high voltage wire with low current or near a wire that has low voltage but high current and explain.
Well for a.) I think that the coil should be placed perpendicular to the wire. This would line the coil up with the magnetic field going down the middle of the coil. This would induce the most current and current is proportional to voltage in V=IR so this should be right. For b.) I would want to place the coil next to a high current wire. This is because a high current wire has a greater magnetic field which would induce a higher current and the it would be easier to get more voltage. Could someone tell me if this is correct?
Yes you are correct.
You could have some fun by putting numbers and formulas on that
try to find (on the net?) some typical lines dimensions (height, distance between cables, ...) and operating characteristics (voltage, current).
Consider some design for the "receiving" coil ...
  • · Replies 0 ·
