| Thread Closed |
Capacitor Voltage Rating |
Share Thread | Thread Tools |
| Apr14-07, 04:33 PM | #1 |
Hi,
What is the rule of thumb for choosing the voltage rating of a capacitor? Should it be twice the operating voltage or is this overkill? Thanks |
| Apr14-07, 05:30 PM | #2 |
It really depends on the application. Double the voltage may be a good rule of thumb, but you may want to consider what the voltage MAY go to in case of a circuit malfunction. Also, a consideration may be the extra cost involved using a higher rated capacitor vs. the probability of an actual failure of the capacitor.
| Apr14-07, 05:37 PM | #3 |
In most capacitors the plates are soaked up in various chemicals, and also are electroplated. So if you exceed the max voltage, a chemical reaction takes place that can eat away the plates, make them rough and punch holes.
So obviously the damage is proportional to voltage exceeded, and time. It's all different for every cap. |
| Apr14-07, 09:42 PM | #4 |
This is a tough one to give a general answer to. Basically it is vendor and material specific so consult the datasheet of your part to be sure. In practice I usually use 2/3 during the design phase then check and optimize (for size and cost) later when doing placement and part consolidation.
To find out more do a google for "capacitor derating". I got some good hits, like this one http://www.nemcocaps.com/PDF/TIPSDESIGNUSE.pdf |
| Apr14-07, 09:46 PM | #5 |
Oh, by 2/3 I meant the derating value
Vmax = Vcap_rating * 2/3 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Capacitor Voltage Rating
| Voltage across capacitor | Engineering, Comp Sci, & Technology Homework | 2 | ||
| How do I find Capacitor rating to start / run Single phase motor | Electrical Engineering | 5 | ||
| min voltage rating of capacitor | Introductory Physics Homework | 0 | ||
| Current/Voltage rating on power cord | Electrical Engineering | 2 | ||
| Voltage across a capacitor | General Physics | 1 | ||
