Im not sure if this is the correct formula for this question, corect me
  • Thread starter Thread starter ImsoFly
    Formula
The problem involves a two-stage toy rocket and its velocity change during the burning of the second stage. The original poster is uncertain about the correct formula to use for calculating the distance traveled as the rocket accelerates from 12 m/s to 40 m/s over a period of 5 seconds.
  • Exploratory, Assumption checking
  • Participants discuss the use of the equation Δt = Δv/a and whether the change in velocity should be calculated as (40-12). There is also a focus on identifying knowns and unknowns in the context of the problem.
Some participants have provided guidance on substituting known values into the equation, while others are questioning the assumptions about the knowns in the problem. Multiple interpretations of how to apply the formula are being explored.
The original poster expresses confusion about the application of the formula and the significance of the time duration already provided in the problem statement.
ImsoFly
Im not sure if this is the correct formula for this question, please corect me
hi this is the problem: the burning of the second stage of a two stage toy rocket takes the rocket from 12 m/s to 40 m/s in 5.0s. How far does the rocket during this time?
would i use delta t= delta v/a ?
Yes, you would need to use that equation.
Thanks neutrino.. but would i do (40-12) to find the velcoity?
What are the 'knowns' in [tex]\Delta t = \frac{\Delta v}{a}[/tex]? Substitute them and find the unknown.
the knowns are velocity and acceleration, yeah i know that you substitute them but would i do (40-12) to find the velcoity?
so like for (40-12) do i plug that in velocity together?
Are you sure about that?
Delta v is change in velocity = Final velocity - Initial Velocity = 40-12.
Yeah, so it's 23 but i was just saying...how would i put that in the formula in the proper way...
delta t= delta v/a, delta t= (40-12)/5.0s, delta t =28m/s /5.0s = 5.6s
therefore the rocket traveled for 5.6 s?
Units are important physics, and the Second is a unit of time.
It has already been stated in the problem that the rocket has been moving for 5 seconds when it's speed changed from 12 to 40 m/s. Acceleration is a measure of how velocity changes with time.
Okay...thanks for taking your time :rolleyes:
  • · Replies 17 ·
  • · Replies 17 ·
