Charge on Conventional Alum Foil
  • Thread starter Thread starter Ronnin
    Charge
The discussion revolves around the maximum electric charge that can be applied to household aluminum foil before it overheats or ignites. Participants explore the relationship between charge, current, and the thermal properties of aluminum in this context.
  • Participants question the distinction between electric charge and current, with some suggesting that current is the relevant factor for heating. Others propose hypothetical scenarios to explore how charge accumulation might lead to heating, while also considering the physical properties of aluminum.
The conversation is ongoing, with various interpretations of the problem being explored. Some participants have offered insights into the factors that influence heating in aluminum, while others express caution about conducting experiments without understanding the associated risks.
There is a concern regarding fire hazards related to the experiment, and participants emphasize the need for careful consideration of the thermal energy thresholds involved.
Ronnin
Does anyone happen to know the maximum electric charge that can be applied to ordinary household alum foil before overheating to ignition?
Sorry but your question does not make sense. Do you mean current, in amperes? Because merely holding a net charge, in coulombs, does not heat up anything.
If you are talking current, then you will need to specify how narrow the piece of foil is. The crucial matter is the cross-sectional area through which the current will flow.
Yes, known maximum amps would be fine. Even in C there must be a threshold to which maximum (combustion in this case) thermal energy is achieved.
I thought Chi gave a good post. for piling up charges, let's take an absurd example, and assume that we have an aluminum sphere in the vacuum of space and with no nearby electrical fields. Imagine the charge fairy could pluck electrons from atoms far removed and gently deposit them on the aluminums surface. By what mechanism do you imagine that the aluminum would heat. I have no point of view, just wondering what yours might be?
OTOH, movement of electrons in a confined material of arbitrary volume implies heat. They bang around to such an extent that we have both microscopic and macroscopic versions of Joule heating. Bad if you're tying to make a supercomputer the size of a bread box, good if you're arc welding.
To try to formalize problem, consider a situation where to get from point a to point b involves traversing a thin patch of aluminum. You might even call this an electrical fuse. Its not as simple as I suspect the following notions would point to:
For aluminum you have the following properties to consider--at what temp does it melt, what resistance does it offer to electrical passage, and how nuch heat energy is required to heat a gram a single degree. As current moves, it heats in relation I^2*R where I is in amps and R is resitance. Now like pipes for water, a very thin strand of aluminum will have the greatest R. Since it has little mass, it takes very little heat to gain temperature fast.
Etc, etc, Point is is you want to know how much current is required to melt or even blow a hole thru aluminum as in vaporize, depends on a lot of variables.
Thank you guys so much for the replies. I will do some figuring. I just didn't want to attempt an experiment without knowing the fire hazard.
Good idea! I've done some inadvertent arc welding :redface: while using the caps for strobe circuit in throw away camera!
You will be the first to find out. Keep us posted.
