Natural frequency of tuning fork
The problem involves determining the natural frequency of a tuning fork that is dropped from rest into the Grand Canyon, with a recorded frequency of 1783.0 Hz after a specific time interval. The context includes concepts from kinematics and the Doppler effect, particularly focusing on the relationship between the motion of the tuning fork and the sound it emits.
  • Participants discuss calculating the velocity of the tuning fork as it falls, with various attempts to derive the distance fallen and the time taken for sound to reach the listener. There is exploration of the relationship between the time of fall and the time taken for sound to travel back to the listener.
The discussion is ongoing, with participants sharing insights and hints about the relationship between the falling fork and the sound detection. Some participants have suggested equating the distances traveled during the fall and the sound's travel time, leading to a quadratic equation. There is no explicit consensus yet, but several productive lines of reasoning are being explored.
Participants are working under the constraints of the problem's parameters, including the given speed of sound and gravitational acceleration. There is a focus on understanding the timing of events related to the fork's fall and sound propagation, with some confusion regarding the implications of the total time recorded.
fruitl00p
Using a highly sensitive parabolic sound collector, Sara records the frequency of a tuning fork as it drops into the Grand Canyon. She drops the vibrating tuning fork form rest at t=0. She records a frequency of 1783.0Hz at t=8.590s. What is the natural frequency of the tuning fork? Use Vsound=343.0 m/s
f'=f*[ v/(v-vs)]
Ok, I know the that the frequency of listener is 1783.0 Hz, that the velocity of the listener is zero, and the velocity of sound is given. My biggest problem is figuring out the velocity of source.
I have tried
v=g*t= 9.8*8.590 = 84.182m/s,
but that turned out not to be the velocity. Then I thought I need to find the distance so I did
d=(1/2)*g*t^2 =(1/2)*9.8*8.590^2 = 361.56 m,
then used the d to find the v by simply doing
v=d/t = 361.56/8.590=42.091 m/s.
However that was incorrect. How do I solve for the velocity of the source?
this is tricky and similar problem was recently discussed so a search may bear fruit. Its a subtle problem insofar as the distance from the listener and the speed of sound need to be accounted for. In other words, at t=8.59s, part of that t was needed to get back to her and so represents a velocity at an earlier time. That help?
I found the previous thread dealing with this problem. At first I thought I understood but I am a bit puzzled. There was the suggestion that I need to figure out the speed of fork had when it emitted the sound that arrived at the detector at t= 8.590s.
The hint was: "If the fork falls for T seconds it travels a distance D. Sound emitted at that time takes D/c seconds to reach the detector. The total time must equal t=7.88 seconds."
I keep rereading this and I am not grasping the hint yet. So the fork falls for a certain amount of time and naturally travels a distance. So I find the distance the fork travels. Using that I find how long it takes to reach detector by using the distance found divided by the velocity of sound in order to find that time.
It takes x s to reach the detector, but the total time is in my case 8.59 s.
So far if I do
D= 1/2 *g*t = 1/2*o.e*8.59= 361.56 m
its takes D/c seconds or 361.56/343 = 1.054 s to reach detector.
Now I'm a bit stuck. There is a 1.054s delay? so though the total time is 8.59s, I subtract the 1.054 from 8.59s? Am I on the correct track?
not quite (besides it's 1/2 gt^2) but getting there.
we don't know the exact delay as this depends on the distance fallen, but your eqn for delay, t'=y/343 is right. we also know y as function of t, that's
1/2at^2. we know that t+t1=8.59s
I meant (1/2)*g*t^2=d. I got the answer 361.54m from that not the one I wrote incorrectly:blushing:
I'm a bit tired so I apologize if what I type down doesn't make sense.
What I am trying to find the moment when the detecor begins detecting fork. So finding the time delay helps me find the distance before the time delay began. I thought I could find the distance using the above equation, but if that is not correct, then I can't picture another way finding the "total distance".
So I find the time delay and use that and total time to find moment the detector begins detecting. From that I can find the distance at the moment. then do vs=sqrt2gd, or something like that. Is that still far off?
FL, don't despair and given the range of questions over the w/e I got to wonder what you been up to over the last few weeks.
Only envy on this end, but
equate
1/2gt^2 with (8.59-t)* 343. do you see what I have done?? we equate the same Y from fall and the time it takes to get back. Its a quadradic. Solve it and you're 80 percent done.
FL, I'm just adding to what DD is driving at but sometimes it helps to hear it a little differently, so here goes: There are two events going on, the fork falling to a certain point, and the sound getting from that point back to Sara's ear, and what both events have in common is the distance that is covered. It does take different times for each event but those times are related (Down time+Up time= 8.59sec). So write out an equation for the unknown distance based on free fall (T=down time), and another equation based on the speed of sound and (T=up time). Now set these two expressions for distance equal to each other and you should have the quadratic equation that DD referred to. Just remember to write it all out in terms of just Tdown or Tup and you can use the quadratic formula to solve for time. Knowing Tdown, you can get your free fall velocity, just as you tried in the first place. Hope this helps.
I had some homework problems that were due this evening so now I can come back to this hmwk problem! Ok, I did the quadratic formula
I ended up getting 4.9t^2 +343t -2946.37 =0 I ended up getting t =7.735s.
bdrosd, your explanation of T up and T down made me more confused unfortunately. I understand that the total time is 8.59 so the time its traveling down plus the time it takes for the detector to detect is equal to that total time. So what time did I end up finding? The time when the fork gets immediately detected?
Because after I found this time I applied it to the equation .5*9.8*t^2=d
then used that d to find vs. So I tried .5*9.8*7.735^2= 293.216 m
but then I used that d and found vs=sqrt2*g*d= sqrt 2*9.8*293.216=75.80 m/s
f'=[v/v+vs]*f
f'*[v+vs/v]=f
1783.0*[343+75.80/343]=f
f=2177 Hz
Did I finally figure it out?:confused:
Actually bdrosd, I don't think it really confused me...I just needed to think about the scenario you illustrated. Well I hope I understood what you said!
I didn't check the Doppler shift, but the time was right.
don't forget that v=at, so you could have saved yourself a step.
v=9.8*7.735=75.8
Good job!
Thanks! I got the correct answer.
9K
