Can a Complete Metric Space Have Empty Interior?
The discussion revolves around the properties of complete metric spaces, particularly focusing on whether such spaces can have an empty interior. Participants explore definitions and examples related to metric spaces, completeness, and the concept of interior points.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants examine the implications of a metric space having an empty interior, questioning if completeness can coexist with this property. They discuss examples such as single-point and two-point metric spaces, and the relevance of considering spaces in isolation versus as subsets of larger spaces.
The discussion is active, with various interpretations being explored. Some participants suggest that completeness and empty interior can coexist under certain conditions, while others question the significance of these edge cases. There is no explicit consensus, but several lines of reasoning are being developed.
Participants note that the definition of interior points may vary depending on whether the metric space is considered in isolation or as part of a larger space. The empty set is also brought into question regarding its completeness, adding another layer to the discussion.
pivoxa15
Can a complete metric space have empty interior?
In mathematical analysis, a metric space M is said to be complete (or Cauchy) if every Cauchy sequence of points in M has a limit that is also in M.
But if M has no Cauchy sequence to start with or anything else for that matter (i.e have empty interior than it can also be labeled as complete? Or is my understanding lacking some important information?
A single point constitutes a trivial metric space. It's complete, open, closed, compact and lots of other things, too!
A single point also has empty interior.
What about a metric space with 2 points? It still has empty interior.
True. Guess I'd better think again.
We'd better be a little careful here. Interior and exterior only have nontrivial meaning if we are speaking of the metric space as a subset of another space. If we are speaking of a single point space {x} in isolation then the interior of {x} is {x}. If we are speaking for example of {0} as a subset of the reals, then it has empty interior.
Interior of the whole metric space is always non empty.
So the subspace of a complete metric space is compelete so has non empty interior? Since we could have a sequence of points starting in the large metric space and obtaining a limit in this subspace. Where this limit point can be in the interior of the subspace. Hence non empty interior for this subspace?
The interior of a metric space X is X itself. So a metric space has empty interior iff that metric space is itself empty. The empty set together with the empty function is a metric space.
Is the empty set also complete?
pivoxa15, this is a sad moment. Think!
From the definition
I'd say yes because there is no Cauchy sequence or any sequence in the empty set.
I would agree. But are these void case problems really that interesting? Is the empty set colorless?
That`s the right one
