Ampere's circuital law on finite length wire
The discussion centers on the application of Ampere's circuital law and Biot-Savart's law to finite length wires, exploring the implications of current behavior in such scenarios. Participants examine the conditions under which these laws apply, particularly in relation to steady currents and closed loops.
  • One participant questions why Ampere's circuital law yields incorrect results for finite length wires, suggesting that charge accumulation may indicate non-steady current.
  • Another participant references a previous discussion in the archives that may provide clarity on the topic.
  • There is a discussion about the applicability of Biot-Savart's law to finite length wires, with one participant noting that it is valid for steady currents.
  • One participant argues that a finite length wire can have a steady current, similar to an infinite length wire, particularly in DC circuits.
  • Another participant points out that a finite segment of wire must be part of a closed loop for Biot-Savart's law to be fully applicable, leading to confusion regarding the calculation of the magnetic field.
  • A later reply suggests calculating the contribution to the magnetic field from a finite straight wire while acknowledging the need to consider the rest of the loop for a complete analysis.
Participants express differing views on the application of Ampere's circuital law and Biot-Savart's law to finite length wires, indicating that multiple competing perspectives remain without a consensus.
Participants highlight the importance of closed loops in the application of Biot-Savart's law and the implications of steady versus non-steady currents, but do not resolve the underlying assumptions or limitations of these laws in the context of finite length wires.
s.gautam
When we apply ampere's circuital law to finite length wire,we get the wrong answer.Why is that? The symmetry rule is being followed,so that's not the problem.
Is it because a finite length wire means that charge is piling up somewhere which means that the current is not steady?
Thanks a lot,that was really helpful.
Pleasure :biggrin: Welcome to the forums!
Hey another thought occurred to me,how can we apply biot-savart's law to determine the magnetic field of a finite length wire? Biot-savart's law is also valid for only steady currents.
I guess I should post it in a new thread.
A wire of finite length can have a steady current, same as a wire of infinite length. Indeed this is precisely the case in any DC circuit.
Yes,it can,but not until its in a closed loop.With biot-savart law,we find out the field of a finite segment of wire which is not a closed loop,and this is what's troubling me.
You're right, it does need to be in a closed loop, but what we can do when we calculate it, is calculate the contribution to the magnetic field of the finite straight wire. It is still left to calculate the field of the rest of the loop. If you're working out of griffith's 2nd ed. See for example Problem 5.37, where you calculate the contribution from one side of the square then multiply it by four.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 27 ·
  • Sticky
  • · Replies 0 ·
