Oil and Water: Investigating Buoyancy and Non-Mixable Liquids
  • Thread starter Thread starter W24JBLV
    Oil Water
The discussion revolves around a problem involving buoyancy and the behavior of a block submerged in a beaker containing oil and water, which are non-mixable liquids. The original poster is attempting to understand the conditions under which the block floats at a specific level between the two liquids.
  • Participants discuss Archimedes' principle and its application to the problem, questioning the specific gravities of the liquids involved. There are attempts to clarify the setup and the assumptions regarding the block's density and its interaction with the two liquids.
The discussion is ongoing, with various interpretations being explored. Some participants have offered insights into the principles at play, while others express confusion about the problem's parameters and the implications of the block's density. There is no explicit consensus on the correct approach or interpretation of the problem.
Participants note that the problem lacks clarity regarding the density of the block and the specific gravities of the liquids. There is a suggestion that the original poster may need to seek further clarification on the question posed.
W24JBLV
I have 2 liquids, Oil and water together in the beaker.
Assuming both liquids are non mixable
I push a block into the water and it floats at halfway between the Oil and the water
See the attachment and please help me I'm stuck and
passing the class depend on this particular problem ...
Do you about Archimedes principle ? A body floats at the level where the weight of the submerged part equals the weight of the displaced liquid.
I think you got your specific gravities the wrong way round.
Yes I'm talking about Archimedes principle..
The Professor gave us this question as it is.. ireally tried to resolve it without
any success. any suggestions??
Mentz pointed out one problem. Another, even if reversed, Water has an sg=1.0, not .3 or .8
Finally as posed and assuming that the block is homogeneous and density greater than either fluid, the object would sink. I'd put this one away until you get clarification.
I'm sorry it is not water the question was two liquids.
Any liquids. assuming they are 0.3 0.8 i used water and
oil just to clear out which one is on the top and which
one is on the bottom.
So ignore the names.
The question didn't say anything about the object's density
the question only wants to know the % of the part that is
in the oil..
My reading of the question is that the block has sg = 0.93. So it would sink in the more dense liquid if it wasn't partly supported by the upper liquid.
Assume the block sinks to a depth x, and has top area A. You get an equation in x because A will cancel out.
maybe this is a deep problem after all, but the diagram shows a density greater than either fluid, but adds to it "in water part". If the density is greater than either fluid it will sink as in completely. Now if the density were somewhere between the two, ok, it should sit in between. But what's most confusing is you state that the object is 1/2 in 1/2 out, but the diagram asks for what percentage is in the oil? I personally (and this is without any mean spirited intention), is that you probably should repeat the course. Our bailing you out at the last minute is not apt to be of value to anyone.
Can Any One Help me with this Question?
by the looks of that picture ( 50%) heh
Help anyone
HELP
SOS
help
help help
help
sorry, I wish I could help, but never took fluids yet. I agree with zenparticle though:shy:
12K
  • · Replies 21 ·
21K
