Calculating Torque on a Potter's Wheel
  • Thread starter Thread starter chamonix
    Torque Wheel
The discussion revolves around calculating torque on a potter's wheel, specifically focusing on angular acceleration and the application of torque. The problem involves a potter's wheel with given dimensions and mass, which is freely rotating and is brought to a stop by applying a force.
  • Mixed
  • Participants explore the calculation of angular acceleration and torque, with some confusion regarding the correct application of formulas. There are attempts to clarify the moment of inertia and its relation to torque.
Some participants have provided guidance on the correct formula for torque and the importance of including angular acceleration in calculations. There is ongoing clarification regarding the moment of inertia for the potter's wheel and its implications for the torque calculation.
There is mention of a discrepancy between calculated values and an expected answer, leading to questions about assumptions regarding the wheel's shape and the calculations involved. Participants are also navigating the constraints of the problem as presented in the homework statement.
chamonix
A potter's wheel of radius 0.50 m and mass 100.0 kg is freely rotating at 50.0 rev/min. The potter can stop the wheel in 6.0 seconds by pressing a wet rag against the rim.
a. What is the angular acceleration of the wheel?
b. How much torque does the potter apply to the wheel?
t=Ia
a=w/t
a. (50/60*2*pi)=5.235988 rad/sec
5.235988/6=.87 rad/sec^2
b. I didnt understand this portion of the question. I tried .5^2*100*5.235988 but the answer was not 11 Nm which I know is the answer. Please help! Any help is greatly appreciated. Thank you.
You want
torque = I * alpha
not I * omega, that is angular momentum. Check your calculation.
Also, if you are assuming the wheel is a solid cylindrical disk, then I = 0.5MR^2, so your above I value is not correct if that's the case.
So...in this case, i should go .5*100*.5^2=12.5?
But the answer given is 11 Nm. I don't understand. :(
You didn't multiply by alpha! torque = I*alpha. If you do that you will get the right answer. You found the right value of alpha in part (a).
Oh, ok. My fault. Ok. Alpha.
so... .5*100*.5^2*.87=10.9=11Nm! ok. Thank you!
Sorry, I must have overlooked that alpha part. Thank you.
15K
12K
