How Does Adding Mass Affect the Angular Speed of a Spinning Disk?
  • Thread starter Thread starter Wurz
    Head Momentum
The discussion revolves around a problem involving a horizontal disk that is spinning and the effects of adding mass to it. Participants are exploring concepts related to angular speed, moment of inertia, and conservation of angular momentum in the context of rotational mechanics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to calculate the moment of inertia of the disk and its rotational energy before and after adding mass. There are discussions about using conservation laws and equations related to rotational mechanics. Some participants question the assumptions made in the calculations and the expected values of the moment of inertia.
There is an active exchange of ideas, with some participants providing suggestions and others expressing their reasoning. While various interpretations and approaches are being explored, no explicit consensus has been reached regarding the calculations or the expected outcomes.
Participants are working under the assumption that no external torques are applied to the system. There is also mention of needing to show work or thought processes before receiving assistance, indicating a focus on understanding the problem rather than simply obtaining answers.
Wurz
A horizontal disk of diameter 12.0cm is spinning freely about a vertical axis through its centre at an angular speed of 72 revolutions per minute. A piece of putty of mass 5.0g drops on to and sticks to the disk a distance of 4.0cm from the centre. The angular speed reduces to 60 revolutions per minute.
1. I need to calculate the moment of inertia of the disc. I can assume that no external torques are applied to the system during this process.
2. A constant tangential force is now applied to the rim of the disk which brings it to rest in 6.0s. Calculate the magnitude of this force.
3. Calculate the rotational energy of the system before and after the putty is added to the disc.
wurz, we need to have you show some work or thought about the problem before helping out. I'll add a suggestion that maybe the first question is like a collision which sticks, where Mvi=(M+m)vf where vi and vf are initial and final velocities.
I think you must use these equations for the questions: L=lw and you must know that I=mr^2. You must also use the analogous equations--similar to those in linear mechanics-- of rotational mechanics equations to solve the problem.
Just plug in and solve.
I understand Denverdoc, thanks for the lead... I think I've got a good answer using the conservation laws: m1v1 = m2v2, and I=mr^2
the answer is very small however, with I = 2.00x10-5kg m^2 does this sound anything like what you would expect??
nice one Atomicbomb22, I got to that point as I read your reply. many thanks for re-inforcing what I had suspected...
Wurx,
uh, might have taken what I suggersted too literally, Its a rotational problem using angular quantities and conservation of these. Without doing the work looks ballpark where 72X=(x+2)60
I think you are missing a factor of 2 in your answer. Use conservation of angular momentum, I'm sure that's what the question intended.
denverdoc said:
Wurx,
How did you get a 2 in there? I'm assuming X and x are representing the same thing.
Yes, the moment of inertia of the disk. For that I recall being 1/2mr^2, while the point is mr^2
  • · Replies 20 ·
18K
  • · Replies 44 ·
