Find Centroid of y=x^2: Homework Help
  • Thread starter Thread starter ghost_301
    Centroid
The discussion revolves around finding the centroid of the area under the curve defined by the equation y=x^2, specifically between the x-axis limits of 0 and 4. Participants express confusion regarding the centroid calculations and the appropriate formulas to use, as well as discrepancies in their results compared to expected answers.
  • Mixed
  • Participants discuss various formulas for calculating the x and y coordinates of the centroid, including integration methods. Some express uncertainty about their calculations and the reasoning behind certain formulas, particularly regarding the integration limits and the setup of the integrals.
There is an ongoing exploration of different approaches to finding the centroids, with some participants offering corrections and clarifications. While some have arrived at specific values for the centroids, there remains a lack of consensus on the correct methodology and results, particularly for the y centroid.
Participants note confusion stemming from differing results compared to their lecturer's answers, as well as the need for visual aids to better understand the area being integrated. There are mentions of potential misunderstandings regarding the area under consideration and the integration limits.
ghost_301
Just studying statics in my first year of university and i do not understand the centroid topic at all. The question goes like this, given a equation y=x^2 , and the x-axis is 0 - 4 , with the lower portion of the graph is highlighted. It is given by diagram but sorry I don't have scanner so can't provide the diagram, but i think the info i gave is enough to illustrate that simple graph. The question ask to find the centroid of it.
The equations i know that i have to use is X-dash and y-dash formula. x-dash formula is (let assume | is integration) "|xdA within 0-4 divided by |dA, (A=|ydx)" and
"|ydA within 0-16 divided by |dA, (A=|xdy)".
I go through all the equations and I found X-dash is 3 which I think is correct, but my y-dash is 9.6, which is doubled of the answer provided to me, 4.8... I don't understand what's wrong with my calculation ?
p/s : I asked my lecturer and he said the |ydA shud be |(y/2)dA , but why ? Please do help me because my exam is coming and I still dun understand this small parts of statics. Thanks for any help.
I've no idea what your formulae mean, but you get the centroid x coord by integrating x*y*dx from 0-4 and dividing that by the integral of y*dx from 0-4.
The rotate the axes and repeat for y.
For the Y centroid
Hey Mentz114, thanks for the help, the formulae u provided helped me to find the x-centroid, which is 3, but i still find the y centroid to be 9.6. Isn't that the formula to find y centroid is integrating y*x*dy from 0-16 and dividing that by the integral of x*dy from 0-16 ?
I got the x centroid to be 8/3, but I could be wrong.
To do y, keep the same vars, but invert the function so
y = sqrt(x)
Should you be taking the square root of 9.6 ?
I found the X centroid to be 3 if using my own formula and yours.
You said "integrating x*y*dx from 0-4 and dividing that by the integral of y*dx from 0-4" to find x-centroid right ?
So |x*y*dx will turned into |x^3dx since y=x^2 , hence i got 64 after integration.
Then |y*dx will turned into |x^2dx since y=x^2 as well, hence I got 21.333 after integration.
So |x*y*dx divide by |y*dx = 64/21.3333 = 3 ( X-Centroid)
You said to keep the same variants, means use 0-4 ? But the function is inverted, shouldn't be using 0-16 ? since y=x^2 , and shouldn't be x=sqrt(y) ?
The integral of x^3dx is (x^4)/4 and the integral of x^2dx is (x^3)/3.
As I said, my answer could be wrong.
I think you've got the hang of it so I'll leave you to it.
Try to understand why the formulae are correct.
Hmm , I can understand for X centroid , but how about Y centroid ? Could you may be write the formula for me to find Y centroid ? As I still haven't found the Y centroid yet ... not the correct one at least ...
I get 9.6 !
[tex]\int_0^{16} x^{\frac{3}{2}} dx[/tex]
divided by
[tex]\int_0^{16} x^{\frac{1}{2}} dx[/tex]
I got 9.6 as well, but my lecturer's answer is 4.8 which is half of it ... that's make me confusing ... :confused:
Metz114 is finding the Y centroid of the wrong area.
Draw a picture. The "width" of the area is that you are integrating over is [tex]4-y^{1/2}[/tex], not [tex]y^{1/2}[/tex].
So the integral you need to evaluate is [tex]\int_0^{16} y(4-y^{1/2})dy[/tex]
The fact that you get twice the right answer is a conincidence.
There we are - corrected.
I imagined the shape wrongly. Thank you, AlephZero
Ok, finally got the answer, but still forgive for my noob-ness, why when find the y-centroid, the integrating have to be https://www.physicsforums.com/latex_images/13/1308807-2.png ? Why the x had become 4-y^(1/2) ? Sorry but anyway, thanks for all the helps.
Here's a picture to show what's going on when you evaluate the two integrals.
huh ? It seems like the atcachment is waiting for approval ... Why need to have approval to show attachment ? Or may be Alephzero is kind enough to send me the link of that gif file ? Thanks ...
  • · Replies 17 ·
22K
