Photoelectric Effect and electric fields
The discussion revolves around a problem related to the photoelectric effect and its connection to electric and magnetic fields. The original poster is tasked with determining the average electric and magnetic field strengths of a laser beam based on given parameters such as photon emission rate, beam diameter, and wavelength.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to relate the energy of photons to the electric and magnetic fields but expresses confusion about the relevance of charge and force in this context. Some participants suggest calculating energy density from the provided information, while others question the original poster's understanding of how to combine area with energy.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the calculation of energy density, and there is recognition that the problem may not pertain to the photoelectric effect as initially thought.
There is a mention of the dimensions of the laser beam and the rate of photon emission, which are crucial for calculating energy density. The original poster expresses frustration and acknowledges a need for clarification, indicating a potential misunderstanding of the problem's requirements.
Dart82
I am having trouble figuring how the info given relates to electric and magnetic fields.
A laser emits 1.38x10^18 photons per second in a beam of light that has a diameter of 1.96 mm and a wavelength of 518.0 nm. Determine each of the following for the electromagnetic wave that constitutes the beam.
(a) the average electric field strength in N/C
(b) the average magnetic field strength in T
E = F/q for electric field
F = qvB sin(theta) for magnetic field
E=hf=hc/lambda for energy of a photon
i solved for E the energy of a photon:
h*c/(518x10^-9m) = 3.84x10-19 Joules
I am not just some slacker begging for an answer; i have a high B in this class! i don't see how in the world the concept of the photoelectric effect can relate to electric and magnetic fields if i don't know q, F, B. I am completely lost here - someone please help!
The photoelectric effect is important here because you are given the rate of emission of photons in the beam and the wavelength (hence energy) of each photon. Together with dimensions of the beam this gives you the energy density in the beam. This energy density could also be calculated from averaged electric and magnetic fields associated with the light beam. So knowing the energy density should let you calculate the electric and magnetic field energy - hence the field intensity.
Do i add the area of the laser beam to the energy of each photon (E)? this is so frustrating...
How can you add an area to an energy? Look, the laser runs for one second, emits 1.38x10^18 photons. Those photons are in a cylinder 1.96 mm in diameter and c*1sec long. What's the energy density?
sorry, i misunderstood what you had said about the dimensions of the beam. i think i need to take a break and try this one again later. 5 hours of Physics homework has tweaked my brain a bit too much. thanks for your help Dick.
Yeah, take a break. BTW, this isn't a photoelectric effect problem either.
got it... no photoelectric effect.
