What Happens to the I-V Graph When Voltage Polarity Is Reversed?
  • Thread starter Thread starter AngelofMusic
    Law Ohm's law
The discussion revolves around the implications of reversing voltage polarity on the I-V graph in the context of Ohm's Law. Participants explore the relationship between current and voltage, particularly focusing on how changes in polarity affect the graph's characteristics.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss whether reversing voltage polarity would maintain the same linear relationship or result in a negative slope. There is also mention of the common practice of graphing I as a function of V rather than the other way around.
Some participants have provided clarifications regarding the nature of the graph and the significance of slope, while others have acknowledged corrections in their understanding of the graphing approach. The conversation appears to be productive, with participants actively engaging in conceptual clarification.
There is a mention of the common practice of plotting I as a function of V, which may influence how participants interpret the graph. Additionally, the discussion touches on the linearity of the graph depending on the resistance of the component, indicating that assumptions about resistance may be relevant.
AngelofMusic
A very quick question about Ohm's Law:
When I graph I (x-axis) vs. V (y-axis), I would get the standard linear relationship specified by Ohm's Law.
One question asked: What would happen if the voltage were reversed? (I think it means what would happen if the polarity was reversed.)
I think that the graph should remain the same, because then V would become negative and so would the current. But some others are saying that this would result in a negative slope for the graph.
Can anyone help?
The slope of the graph is R, the resistance. Therefore, in a simple case such as this, it cannot be negative. You are correct then, both V and I would be "reversed".
I should also mention, just for general knowledge, that it is more common to draw a graph of I as a function of V, i.e I(v) rather than V(I) that you drew. The graph I(v) of an electric component describes the current through the component as a function of the potential on it, and its slope is the conductivity of the component (which is 1/R). It is a more useful graph because usually you control the V on the component, and not the current I through it. :smile: Also, I(v) (or V(I)) are not always linear, they are only linear when the resistance of the component is constant. In light bulbs, for example, the resistance changes as the heat grows, so the graphs of it will not be linear at all.
Thanks a lot for your clarification! And upon more careful reading, I was asked to plot the I-V curve, which indeed has I as a function of V. So thanks for your reminder as well! Caught my mistake! :-)
  • · Replies 44 ·
