Differentiation [ (7x^3+4)^(1/x) ] / Integration [ x^x(1+ln(x)) ]
The discussion revolves around the differentiation of the expression \((7x^3 + 4)^{\frac{1}{x}}\) and the integration of \(x^x(1 + \ln(x))\). Participants are exploring the methods and reasoning behind these calculus problems.
  • Mixed
  • The original poster attempts to differentiate the first expression using logarithmic differentiation and expresses uncertainty regarding the integration of the second expression. Some participants suggest substitution methods for the integration problem, while others provide feedback on the differentiation attempt, noting potential errors.
Participants are actively engaging with the problems, offering suggestions and corrections. There is a recognition of a mistake in the differentiation process, and some guidance is provided regarding the integration approach. Multiple interpretations and methods are being explored without a clear consensus.
There is an indication that the original poster is constrained by previous experiences and assumptions about the functions involved, particularly regarding the relationship between differentiation and integration of the expressions.
unique_pavadrin
Differentiate the following expression leaving in the simplest form:
[tex]\left( {7x^3 + 4} \right)^{\frac{1}{x}}[/tex]
Integrate the following leaving in the simplest form:
[tex]x^x \left( {1 + \ln x} \right)[/tex]
2. The attempt at a solution
Here is my worked solution for the differentiation problem:
[tex]\[<br /> \begin{array}{l}<br /> \frac{d}{{dx}}\left[ {\left( {7x^3 + 4} \right)^{\frac{1}{x}} } \right] \\ <br /> y = \left( {7x^3 + 4} \right)^{\frac{1}{x}} \\ <br /> \ln y = \left( {\frac{1}{x}} \right)\ln \left( {7x^3 + 4} \right) \\ <br /> = \frac{{\ln \left( {7x^3 + 4} \right)}}{x} \\ <br /> \frac{d}{{dx}}\left[ {\ln \left( {7x^3 + 4} \right)} \right] = \frac{1}{{7x^3 + 4}}.\frac{d}{{dx}}\left[ {7x^3 + 4} \right] \\ <br /> = \frac{{21x^2 }}{{7x^3 + 4}} \\ <br /> \frac{d}{{dx}}\left[ {\frac{{\ln \left( {7x^3 + 4} \right)}}{x}} \right] = \frac{{x\left( {\frac{{21x^2 }}{{7x^3 + 4}}} \right) + 1\left( {\ln \left( {7x^3 + 4} \right)} \right)}}{{x^2 }} \\ <br /> = \frac{{21x^3 + \left( {7x^3 + 4} \right)\ln \left( {7x^3 + 4} \right)}}{{x^2 }} \\ <br /> \\ <br /> \frac{1}{y} = \\ <br /> y' = y.\frac{{21x^3 + \left( {7x^3 + 4} \right)\ln \left( {7x^3 + 4} \right)}}{{x^2 \left( {7x^3 + 4} \right)}} \\ <br /> = \frac{{\left( {7x^3 + 4} \right)^{\frac{1}{x}} \left( {21x^3 + \left( {7x^3 + 4} \right)\ln \left( {7x^3 + 4} \right)} \right)}}{{x^2 \left( {7x^3 + 4} \right)}} \\ <br /> = \frac{{\left( {7x^3 + 4} \right)^{\frac{1}{x} - 1} \left( {21x^3 + \left( {7x^3 + 4} \right)\ln \left( {7x^3 + 4} \right)} \right)}}{{x^2 }} \\ <br /> \end{array}<br /> \][/tex]
______________________________________
For the integration problem I am not quite certain on how to integrate the expression given. I know from previous experience that the expression x^x when differentiated will give x^x(1+ln(x)).
many thanks for all suggestions and help
unique_pavadrin
For the integration, my first thought was to make a substitution like u= xx. Of course, to do that I would need a derivative for xx. Find the derivative of xx and think you will realize that the integral is surprizingly easy.
I got this result, with a small difference:
(4 + 7*x^3)**(-1 + 1/x)*(21*x^3 - (4+7*x^3)*Log(4 + 7*x^3)))/x^2
The mistake appeared probably in the 7th line of your calculation.
You probably forgot the minus sign from the rule:
(a/b)' = (a'b-ab')/b²
Since from previous experience you know the integral is x^x, and x^x happens to appear in that integrand, the easiest way out will always be the substitution which gives the whole integrand! Same goes for any integral like that.
thank you for the reply and thank you lalbatros for point out my stupid mistake
  • · Replies 18 ·
  • · Replies 25 ·
  • · Replies 105 ·
13K
