Eigenstates of S^2: Calculating Eigenvalue for a Quantum System
  • Thread starter Thread starter PhysicsForums
    Eigenstates
The discussion focuses on calculating the eigenvalue of the operator S^2 for a specific quantum state represented as a linear combination of states α(1)β(2) and β(1)α(2). The initial calculations incorrectly summed the contributions from the S operators, leading to a non-zero result. The correct approach involves using the representations of the S operators, specifically S_{1x}, S_{2x}, S_{1y}, and S_{2y}, to arrive at the conclusion that the eigenvalue is indeed zero when calculated correctly.
  • Understanding of quantum mechanics and angular momentum operators
  • Familiarity with the notation and properties of spin states
  • Knowledge of eigenvalues and eigenstates in quantum systems
  • Proficiency in manipulating quantum operator algebra
  • Study the properties of angular momentum operators in quantum mechanics
  • Learn about the representation of spin states and their transformations
  • Explore the concept of eigenvalues and eigenstates in quantum systems
  • Investigate the mathematical techniques for summing operator contributions in quantum mechanics
Students and researchers in quantum mechanics, particularly those focusing on angular momentum and spin systems, will benefit from this discussion.
PhysicsForums
I need to show: [tex]S^2 \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)[/tex] has an eigenvalue of zero.
The attempt at a solution
[tex]S_1^2 \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)=\hbar^2 \frac{3}{4} \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)[/tex]
[tex]S_2^2 \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)=\hbar^2 \frac{3}{4} \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)[/tex]
[tex]2S_{1z}S_{2z} \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)=-\hbar^2 \frac{1}{2} \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)[/tex]
[tex]\left( S_{1+}S_{2+}+S_{1-}S_{2-} \right) \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)=0[/tex]
As you can see, these values do not add up to zero. [tex]\hbar^2 \frac{3}{4} + \hbar^2 \frac{3}{4} -\hbar^2 \frac{1}{2} =2 \hbar^2[/tex]
I am not sure where my calculations went off, if you would like to see more work, please ask.
S_1x S_2x should equal S_1z S_2z.
Do it more carefully.
Your result is wrong because:
[tex] \left( S_{1x}S_{2x}+S_{1y}S_{2y} \right) = \left( S_{1+}S_{2-}+S_{1-}S_{2+} \right)[/tex]
so that
[tex] \left( S_{1+}S_{2-}+S_{1-}S_{2+} \right) \left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)= -\left( \frac{1}{\sqrt{2}} \left[ \alpha(1) \beta(2) - \beta(1) \alpha(2) \right] \right)[/tex]
You also summed in the wrong way all the eigenvalues. You have:
[tex] \hbar^2 \frac{3}{4} + \hbar^2 \frac{3}{4} -\hbar^2 \frac{1}{2} =1 \hbar^2 [/tex]
If you sum the new -1 value got from the correct representation of S operators you get 0.
(Sorry for the top up, just found a wrong answer and felt like to provide the correct solution :))
