Magnetic Braking: Examining Relative Motion of Wire and Field
  • Context: Graduate
  • Thread starter Thread starter EFuzzy
    Braking Magnetic
The discussion revolves around the phenomenon of magnetic braking as it pertains to a rectangular loop of wire moving through a uniform magnetic field. Participants explore the induced current, the forces acting on the wire, and the relative motion of electrons and the wire itself. The scope includes conceptual understanding and technical reasoning related to electromagnetic effects.
  • Some participants propose that there are two components to the motion of electrons: one relative to the wire and one of the wire relative to the magnetic field.
  • Others argue that the motion of the electrons due to the wire's movement does not contribute to the electromagnetic effect and can be ignored, focusing instead on the change in magnetic flux to induce emf.
  • A participant questions the claim that the motion of the wire does not affect the electromagnetic effect, suggesting that the drift velocity of electrons is slow compared to the wire's motion.
  • Another participant clarifies that the forces on electrons depend only on the velocity component perpendicular to the magnetic field, implying that only the relative velocity of the current matters.
  • There is a discussion about the net force acting on the loop, with some asserting that the forces on the top and bottom edges cancel out, while the net force is directed to the left due to the induced current.
Participants express differing views on the contributions of the motion of electrons versus the wire in generating electromagnetic effects. The discussion remains unresolved regarding the implications of these motions on the net forces acting on the wire.
Participants reference the need for a diagram to clarify the forces and motions involved, indicating potential limitations in understanding without visual aids. There is also mention of the dependence on specific reference frames, which may affect interpretations of the forces at play.
EFuzzy
When a rectangular loop of wire is drawn into a uniform magnetic field, there will be an induced current. What I don't understand is whether there are two components to the motion of the electrons, one of the current relative to the wire, and one of the whole wire relative to the field.
If we just consider the constant current relative to the wire, then the top and bottom edge's magnetic force cancel out. However, after taking into account the movement of the whole loop, there should be a net downward force.
However, my textbook states that there is only a force to the left. Maybe I'm looking at the wrong reference frame. Could someone explain this?
Thanks.
The motion of the electrons due to the motion of the wire does not contribute to an electromagnetic effect here and can be ignored.
The induced emf in the loop is the time rate of change of the flux through the loop ie: the motion of electrons is caused by the magnetic flux inside the loop changing.
If the loop is being drawn into a uniform magnetic field from a region where there is no field, so that part of the loop is outside and part is inside, there is a change in the magnetic flux ([itex]\phi = \int B\cdot dA[/itex]) through the loop and an emf in the loop: [itex]emf = d\phi/dt[/itex]. If it is simply moving in a uniform magnetic field, there is no change in the flux through the loop so there is no emf.
[/quote]I might have to see a diagram here to understand where you are having a problem.
I assume the rectangular loop is moving to the right into the magnetic field. The flux through the loop is increasing, so there is an induced emf in the wire. The emf in the loop creates a current in the loop. The current in the vertical section of wire on the right side of the loop creates a magnetic field around the wire that interacts with the applied magnetic field in a way that opposes its motion through the field - so it pushes to the left. Since the vertical section on the left is not in the applied field, there is no force on the left side of the loop. So the net force is to the left. The current in the horizontal sections of the loop interact with the applied magnetic field and push in opposite directions so they cancel out. The total net force is left, opposite to the direction of motion.
AM
Thanks for your response, however, I'm having trouble understanding this part:
Isn't the net drift velocity of the electrons exceedingly slow? In that case, the motion of the wire might actually be faster than the motion of electrons relative to the wire.
The motion of the wire moves the electons and protons at the same speed. The wire is electrically neutral. How are you suggesting that this motion creates an electromagnetic effect?
AM
the forces on the electrons will only be according to the velocity component which is perpendicular to the magnetic field, therefor it is only dependent on the velocity of the current in the wire. why? because the velocity of electrons can be made of two components, the velocity in reference to the wire, and the velocity of the wire itself - the velocity of the wire is in the same direction as the magnetic field therefor will not create force, and the other velocity is perpendicular to the magnetic field, therefor will create force.
so the force will only be dependent on one component of the velocity, the one in relative to the wire.
AM
Oh, I think I see where I went wrong then. :cool: Thanks for your help!
  • · Replies 20 ·
  • · Replies 20 ·
