How do I calculate x(t)+x(-t) for t<0 and t>=0?
  • Thread starter Thread starter dervast
The discussion revolves around calculating the expression x(t) + x(-t) for two cases: when t < 0 and when t >= 0. The piecewise function is defined as x(t) = -3t for t < 0 and x(t) = t for t >= 0.
  • Exploratory, Assumption checking
  • The original poster attempts to compute x(t) + x(-t) for both cases, but expresses confusion over discrepancies between their calculations and those in the teacher's book. Some participants question the reasoning behind the original poster's interpretation of x(-t) when t < 0 and t >= 0.
Participants are actively engaging with the problem, offering clarifications and questioning assumptions. There is no explicit consensus on the calculations, and multiple interpretations of the piecewise function are being explored.
The original poster expresses frustration with their understanding of the problem and the conflicting information from the teacher's book. There are also indications of uncertainty regarding the definitions and conditions of the functions involved.
dervast
Hi i have to read mathematics over 7 years and now i can't even solve a simple equation
I hav3e the following
x(t)=-3t for t<0 and
x(t)=t t>=0
I want to calculate the x(t)+x(-t) for t<0 firstloy and then for t>=0
For t<0
x(t)+x(-t)=-3t+t (x(t)=-3t cause x is negative x(-t)=t cause the negative of the negative -t is the t which is t)
The problem is that my teachers book says that x(t)+x(-t)=-3t-t and i can't understand how he calculates that
Now for t>=0 x(t)+x(-t)=t-3t (x(t)=t cause it is positive and x(-t)=-3t cause the negative of t>=0 is the t<0 which makes x(t)=-3t..
My teacher again argues with me cause he calculates in his note
x(t)+x(-t) as =t+3t
So what i am doing wrong ?:(
dervast said:
For t<0
Since t < 0, it follows that -t > 0, hence x(-t) = -t. I can't understand your reasoning for why x(-t) = t when t < 0.
t is not necessarily positive. It could be exactly 0.
Again, I don't know what you're doing. When t is non-negative, -t is non-positive, so either -t = 0 or -t < 0. If -t = 0, then x(-t) = 0 = 3(0) = 3t. If -t < 0, then x(-t) = -3(-t) = 3t.
thx for your answer one more question then
y(t)=2t+2 for -1<=t<0
y(-t)=-2t+2 for ? i first multiple with - or first i convert the > to < ?
If y(t)=2t+2 for -1<=t<0 is the only definition you are given, then in order to be able to find f(-t) using that definition you must have, multiplying each part by -1, -(0)< -(-t)<= -(-1). In other words, 0< t< 1. And, in that case, y(-t)= 2(-t)+ 2.
