How Does Firing Shells Affect the Speed of a Recoiling Car?
  • Thread starter Thread starter neelakash
    Momentum
The discussion centers on the physics of a car firing shells while resting on a frictionless surface, specifically analyzing the effects on the car's speed after firing two shells. The total mass of the system is 50m, where m is the mass of a single shell, and the shells are fired with a muzzle speed of 200 m/s. Two methods were employed to solve the problem: the first method utilized the conservation of linear momentum for the entire system (car plus both shells), while the second method analyzed the system after each shot separately. Both methods yielded consistent results, demonstrating the validity of using different systems in momentum conservation.
  • Understanding of conservation of linear momentum
  • Familiarity with relative velocity concepts
  • Basic knowledge of kinematics in physics
  • Ability to solve equations involving multiple variables
  • Study the principles of conservation of momentum in different reference frames
  • Learn about the effects of mass ejection on the velocity of a system
  • Explore advanced kinematics problems involving frictionless surfaces
  • Investigate real-world applications of momentum conservation in vehicle dynamics
Students of physics, particularly those studying mechanics, educators teaching momentum concepts, and anyone interested in the dynamics of systems involving mass ejection.
neelakash
A car with a gun and a man is rest on a frictionless floor.The total mass is 50m where m is the mass of a single shell.Now,the man fires each shell with a muzzle speed 200 m/s.and the car recoils.What is the speed aftyer the 2nd time firing?
Conservation of Linear momentum
I did the problem in these two ways---Both are correct.Now,in the first problem, I have used car+1st shot bullet+2nd shot bullet as the system.
Whereas in the 2nd method,I used two different systems per shot--- composed of the car+ one bullet.Then,I added the answers vectorially
.Please let me know why this method gives correct result.
1st method:
R_CM=[1/(50m)][49m*r_cf+m*r_sf]
(d/dt)R_CM=[1/(50m)] [49m*v_cf+m* v_sf ]=0
[v_sc=v_sf-v_cf where v_sc,v_sf,v_cf are velocity of shell w.r.t. car,velocity of shell w.r.t. floor, velocity of car w.r.t. floor]
49m*v_cf+m*[ v_sc + v_cf ] =0
This gives,v_cf=-[v_sc/50 m/s
=-200/50 (i) m/s where (i) is the unit vector
v_sf=(49/50)v_sc
w.r.t the same frame,
{48m*v'_cf+m*[v'_sc+v'_cf]}+m*(49/50)v_sc=0
49v'_cf=-v'_sc-(49/50)v_sc
v'_cf=-200(1/50+1/49)(i)
second Method:
Let an object have mass M and eject a smaller mass m with a relative velocity v in the negative direction. What is the change in the velocity (dv) of M? P_i = P_f ---> Mv_i = (M - m)v_f + m(v_f - v) = Mv_f - mv ---> M(v_f - v_i) = mv ---> Mdv = mv ---> dv = (m/M)v.
Using this general relation, dv_1 = (1/50)*200, and dv_2 = (1/49)*200. Since the initial velocity was 0, the final velocity of M is 0 + dv_1 + dv_2 = (1/50 + 1/49)*200.
I hope I understand now.Since as an observer I always see all of the elements of the system---car,1st and 2nd bullets,I will see the CM at rest.So,the 1st method is appropriate.I was unable to visualise a different system when I am seeing all at a time.OK,I can select another system...as physics remains unchanged.However,in this system,the CM will be moving.
So,selecting (car+2nd bullet) as the system,we may avoid the 1st bullet term,but the CM motion term cannot be avoided.Whereas if I use a single system all the way,I will have to include the 1st bullet term,but there will be no CM motion term.
