How Do Forces F1 and F2 Affect the Speed of a Slider Block?
  • Thread starter Thread starter jjiimmyy101
    Impulse Momentum
The problem involves a 40 kg slider block moving under the influence of two forces, F1 and F2, with the goal of determining its speed at a specific time. The context includes dynamics and force analysis, particularly focusing on the effects of varying forces over time.
  • The original poster attempts to apply the impulse-momentum theorem by calculating the area under a force-time graph to find the final velocity. Some participants question the treatment of forces as scalars and the implications of the pulley system on the net force acting on the block.
Participants are actively engaging with the problem, with some providing clarifications regarding the vector nature of forces and the impact of the pulley system. There is an indication of differing interpretations of the forces involved, but no explicit consensus has been reached.
There is a mention of neglecting friction and the mass of the pulleys and cords, which may influence the calculations. The original poster's calculations are based on an assumption about the forces that some participants are questioning.
jjiimmyy101
Question: The 40 kg slider block is moving to the right with a speed of 1.5 m/s when it is acted upon by the forces F1 and F2. If these loadings vary as shown (in the attachment called graph), determine the speed of the block at t =6s. Neglect friction and the mass of the pulleys and cords.
The graph doesn't really look like I drew it but you can get the picture (I hope).
This is what I did so far:
Equation: mV1 + summation (integral of) F * dt = mV2
So I calculated the area under each part of the graph and added them together like so
40*(1.5) + 30*(4-0) + 10*(6-4) + 10*(2-0) + 20*(4-2) + 40*(6-4) = 40V2
340 = 40V2
V2 = 8.5 m/s
Is this right?
Here's the graph.
Well, F1 acts in the opposite direction of F2 so one of them needs to get a minus sign in your calculations. The graph shows the forces as scalars (i.e it only tells you their magnitutde), not as vectors. Also, if the right cord is pulled by F1, then the force on the block is actually 4 times F1, because of the pulley system.
Ohhhhhhhhhh! Thank-you. I get it now. The answer is 12 m/s.
  • · Replies 27 ·
  • · Replies 24 ·
