Max Compression of Frictionless Blocks & Spring
The discussion focuses on calculating the maximum compression of a spring in a completely inelastic collision involving two blocks with masses m_1 = 2 kg and m_2 = 5 kg, moving at speeds of 10 m/s and 3 m/s, respectively. The spring constant is k = 1120 N/m. The correct approach involves using conservation of momentum to find the combined velocity after collision and then applying energy conservation principles to determine the spring compression. The maximum compression calculated using the correct method is 0.25 m, contrasting with the incorrect calculation of 0.37 m.
  • Understanding of conservation of momentum
  • Knowledge of kinetic energy calculations
  • Familiarity with spring potential energy equations
  • Ability to solve quadratic equations
  • Study the principles of conservation of momentum in inelastic collisions
  • Learn about energy conservation in mechanical systems
  • Explore the relationship between kinetic energy and potential energy in springs
  • Practice solving problems involving mass-spring systems and collisions
Students studying physics, particularly those focusing on mechanics, as well as educators looking to clarify concepts related to collisions and energy conservation.
r16
A block with mass [itex]m_1 = 2 \textrm{kg}[/itex] slides along a frictionless table with a speed of 10 m/s. Directly in front of it and moving in the same direction is a block of mass [itex]m_2 = 5 \textrm{kg}[/itex] moving at 3 m/s. A massless spring with spring constant k = 1120 N/m is attached to the near side of [itex]m_2[/itex]. When the blocks collide, what is the maximum compression of the spring? (Hint: At the moment of maximum compression of the spring, the two blocks move as one. Find the velocity by noting that the collision is completely inelastic to this point).
I tried doing this problem 2 ways, my way and then utilizing the hint (i got the same answer)
When they collide, block 1 will do work on block 2 until their kinetic energies are equal, and at this point the spring will be at it's maximum compression. So:
[tex]W = -\Delta U = \int^{x_f}_{x_0} \mathbf{F} \cdot dx = 1/2kx^2[/tex]
[tex]KE_1 = (.5)(2)(10^2) = 100 \textrm{J}[/tex]
[tex]KE_2 = (.5)(5)(3^2) = 22.5 \textrm{J}[/tex]
Energy available for block 1 to do work on the spring:
[tex]KE_1 - KE_2 = \Delta U = 100 - 22.5 = 77.5 \textrm{J} = 1/2kx^2[/tex]
[tex]x= \sqrt{\frac{2U}{k}} = \sqrt{\frac{(2)(77.5)}{1120}} = .37\textrm{m}[/tex]
The book said the answer was .25m
So I went on to do it the second way, suggested by the hint:
[tex]m_1v_1 + m_2v_2 = (m_1 + m_2)v_3[/tex]
[tex]v_3 = \frac{m_1v_1 + m_2v_2}{m_1 + m_2} = \frac{(2)(10) + (5)(3)}{2 + 5} = 3.5 \textrm{m/s}[/tex]
Now find the kinetic energy when at the instant when both blocks are moving as a unit:
[tex]KE= 1/2mv^2 = (.5)(2+5)(3.5^2) = 43 \textrm{J}[/tex]
Now energy is conserved both before and after the collision so:
[tex]E_f = KE_{\textrm{2 block system}} + U_{\textrm{spring}}[/tex]
[tex]E_i = KE_1 + KE_2[/tex]
[tex]\Delta E = 0 = E_f - E_i[/tex]
[tex]E_f = E_i[/tex]
[tex]43 + U = 100 + 22.5[/tex]
[tex]U = 79.5 \textrm{J} =1/2kx^2[/tex]
[tex]x = \sqrt{\frac{2U}{k}} = \sqrt{\frac{(2)(79.5)}{1120}} = .37 \textrm{m}[/tex]
I've gone over both ways and the math and physics looks pretty solid. Does anyone see an error in my physics / math?
When you solved for v3, you divided by 10 instead of 7.
Thanks that was it. This brings up a good point, which I've been doing a lot lately. I do all of the major mathematics correctly, but I always make some stupid mistake and get the answer incorrect. How do everyone else deal with making those preventable errors?
  • · Replies 16 ·
