Log of i: Can you get logarithms of imaginary numbers?
  • Context: Undergrad
  • Thread starter Thread starter theperthvan
    Log
The discussion revolves around the logarithms of imaginary numbers, particularly focusing on the logarithm of the imaginary unit \(i\). Participants explore various mathematical approaches, implications for integration, and the multivalued nature of complex logarithms.
  • Some participants propose that logarithms of imaginary numbers exist but are multivalued functions, as illustrated by the logarithm of \(i\) being expressed as \( \log(i) = i \left(\frac{\pi}{2} + 2k\pi\right) \) for integers \(k\).
  • One participant attempts to derive the logarithm of \(i\) using the exponential form and concludes that \( \log(i) = 0.6822i \), suggesting a specific numerical value.
  • Another participant discusses the integration of \( \frac{1}{1+x^2} \) and how it relates to logarithms, noting that while logarithms are not strictly necessary for the integration, they can be useful in deriving related formulas.
  • There is a challenge presented regarding the use of logarithms with rational numbers and the implications of logarithmic identities, leading to confusion about the validity of certain transformations.
  • Some participants highlight the need for a branch cut to obtain a unique value for the logarithm of \(i\), indicating that without this, multiple values can arise.
  • One participant emphasizes the necessity of justifying the use of complex numbers when differentiating with respect to real variables.
Participants express differing views on the nature of logarithms of imaginary numbers, with some asserting their existence and multivalued nature, while others focus on specific numerical evaluations. The discussion remains unresolved regarding the implications of these logarithmic identities and their applications.
Limitations include the multivalued nature of complex logarithms, the dependence on branch cuts for unique solutions, and the potential confusion arising from applying logarithmic properties to both real and imaginary numbers.
theperthvan
The reason I was wondering is because integrating 1/(1+x^2) WRT x.
I know the answer is arctan(x), but how about breaking it into partial fractions by doing 1/(1-ix)(1+ix)?
Yes, though it's a mutivalued function so it's not as simple as with natural number.
Let's try to find log(i), given that log is the inverse function of the exponential defined on the whole complex plane.
So, log(i), whatever it is, should be a number such that exp(log(i))=i. Let's say log(i)=z=x+iy... then z is such that exp(z)=exp(x+iy)=exp(x)exp(iy)=exp(x)[cos(y)+isin(y)]=i. Well, x=0, y=pi/2 does the trick. But so does x=0, y=pi/2+2npi for any integer n. So log(i) is actually a multivalued function.
Given a complex number x = a + bi we want to find its logarithm
[tex]c + di = ln(a + bi)[/tex]
Take the exponential of both sides
[tex]e^{c + di} = e^{ln(a + bi)}[/tex]
[tex]e^c e^{di} = a + bi[/tex]
[tex]e^c (cos(\frac{d}{\pi}) + i sin(\frac{d}{\pi})) = a + bi[/tex]
Separating the imaginary and real terms:
[tex]e^c cos(\frac{d}{\pi}) = a[/tex]
[tex]e^c sin(\frac{d}{\pi}) = b[/tex]
To get d, divide one by the other:
[tex]\frac{e^c}{e^c} \frac{sin(\frac{d}{\pi})}{cos(\frac{d}{\pi})} = \frac{b}{a}[/tex]
[tex]tan(\frac{d}{\pi})} = \frac{b}{a}[/tex]
[tex]d = tan^{-1}(\frac{b}{a}) \pi[/tex]
To get c, use the absolute values and Pythagoras:
[tex]|e^c e^{di}|^2 = |a + bi|^2[/tex]
[tex]|e^c|^2 = a^2 + b^2[/tex]
[tex]e^c = \sqrt{a^2 + b^2}[/tex]
[tex]c = ln(\sqrt{a^2 + b^2})[/tex]
Note that you can add/subtract 2pi to d to get more solutions, which is a typical side effect of using arctan.
I haven't read everything you wrote jet...
but I had an Problem too:
i^0 = 1
i^1 = i
i^2 = -1
i^3 = -i
i^4 = 1
It's going on like that,
but if you make de lg of the rationaly numbers...
lg(i^0)=lg(1) ____ lg(i^2)=lg(-1) ____ lg(i^4)=lg(1) ...
then there will be...
0*lg(i)=lg(1) ____ 2*lg(i)=lg(-1) _____ 4*lg(i)=lg(1) ...
____ 0=lg(1) ______ lg(i)=lg(-1)/2 _____ lg(i)=lg(1)/4 ...
NOW IS THAT POSSIBLE?
lg(1)=0 ... That's True...
BUT:
lg(-1)=?
My first Problem...
Just forget it for the moment...
SO: lg(i)=0/4 => lg(i)=0 => lg(i)=lg(1) => i=1 !
Now where was I wrong...?
or is it just that you can't work that way...
as an other example...
i^2= -1
i = -/-1]
i*i = -/ -1 ]*-/ -1 ]
So...
i*i = -/ -1*-1 ]
i*i = -/ 1 ]
i*i = 1 ??
Both time's i=1...
i^0 = 1
i^1 = i
i^2 = -1
i^3 = -i
i^4 = 1
BUT:
lg(-1)=? -> log(-1)=[π/ln(10)]i and in case your wondering ln(-1)=πi
My first Problem...
i^2= -1
i = -/-1]
So...
i*i = -/ -1*-1 ]
i*i = -/ 1 ]
i*i = 1 ??
Both time's i=1...
The fallacy is that √(xy)=√x√y is generally valid only if atleast one of the two numbers x or y is positive. (From Wiki)
[tex] \log{(i)} = i \, \left(\frac{\pi}{2} + 2 \, k \, \pi\right), \; k \in \mathbb{Z}[/tex]
You don't actually need to find ln(i) in order to perform the integration using partial fractions, but I think you will need the following formula:
[tex]\tan^{-1}(z) = \frac{1}{2i} \ln \frac{1-iz}{1+iz}[/tex]
You might want to see if you can derive it (it's not hard).
log (i) = ?
log (i) = x
convert imaginary to exponential form...
thus;
(r)(exp^i) => i = (1)exp^(∏/2)i
then substitute to equation...
log (1exp^(∏/2)i)
basic logarithmic law...
log (ab) = log a + log b
therefore...
log (1exp^(∏/2)i) = log 1 + log exp^((∏/2)i)
log 1 = 0
log exp^((∏/2)i) = i log exp^(∏/2) = 0.6822 i
therefore...
log (i) = 0.6822i
another way to solve log (i)
log (i) = ?
let log (i) = x
therefore...
10^x = i
take the natural logarithm...
ln 10^x = ln i
ln 10^x = x ln 10
ln (i) = ln (1 exp^((∏/2)i) = ln 1 + ln exp^(∏/2)i = (∏/2)i
x ln 10 = (∏/2)i
x = (∏/2)i / ln 10
x = 0.6822 i
same as the answer of my first post...
different solution but one answer...
If you want a unique answer you need to pick a branch cut first.
There are logarithms of [itex]i[/itex], but in terms of the calculus, your problem asks you to differentiate with respect to a [itex]x \in \mathbb{R}[/itex], right?
While the complex numbers contains all the real numbers, you may need to justify why you can get a solution of a real variable using a method with complex numbers.
