I'm clueless. Oscilloscope as resistor
The discussion revolves around estimating the apparent resistance of an oscilloscope in a circuit involving a resistor and a capacitor. The original poster is trying to understand the role of the resistor once the voltage source is removed, specifically in the context of a discharging capacitor connected to an oscilloscope.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the configuration of the circuit, questioning whether the resistor is in series or parallel with the capacitor. There are discussions about monitoring the voltage decay on the oscilloscope and using that data to estimate resistance. Some participants suggest methods for calculating resistance based on voltage readings over time.
The discussion includes various interpretations of the circuit setup and the role of the oscilloscope. Some participants have offered guidance on how to approach the problem, while others are questioning the assumptions made about the circuit configuration and the measurements being taken.
There is uncertainty regarding the exact wiring of the components and whether the oscilloscope is measuring the resistance of just itself or the combined resistance with the resistor in the circuit. Participants also note potential constraints related to the homework rules regarding measurement methods.
KingJaymz
I've thought and thought and thought about this, but I can't figure it out. How might I be able to estimate the apparent resistance of an oscilloscope? We're dealing with an oscilloscope connected to a circuit which uses a resistor and a capacitor. I think this question might have something to do with it. What function does the resistor play in a circuit once the voltage source is removed?
Please help me if you can.
Can you be a little more specific as to how the power source, resistor and capacitor are wired together?
Is the resistor in series or parallel with the capacitor?
Yeah. Shoulda included that earlier. I was hoping it was more of a conceptual question. We have a 1.5 V battery powering a circuit on a breadboard that's got a 47 kiloohm resistor and a 33 microfarad capacitor in it. The resistor and capacitor are in series and the test leads of the oscilloscope are connected to the end of the breadboard circuit and the negative end of the battery. The oscilloscope completes the circuit. Did I explain that well?
OK, so when you remove the power source, the cap is discharging through the O-scope, right?
If that is the case, you can monitor the voltage on the scope as it varies with time. The voltage will be decaying.
You can find the resistance by solving this equation for R:
v(t)=V*e^(-t/RC)
where:
v(t) is the voltage at a given time
V is the initial voltage, 1.5 volts in your case
t is the particular time you are reading the voltage v(t)
C is the capacitance of the capacitor
R is the resistance of the O-scope, for which you are solving.
Solve this equation for R (hint: you will have to take the ln of both sides to eliminate e) and you will have general equation with which you will perform your calculations.
I would take "snapshots" of the voltage at specific time increments, say maybe every 5 seconds, and come up with a table.
For example:
t=0 , v(t)=1.5v
t=5 , v(t)=.900v
t=10 , v(t)=.700v
Monitor the voltage for about 1 minnute, that should give enough data.
Plug these values into the equation you found, and calculate R at each one of these data sets of t and v.
Average the values, and you will have a good approximation of resistance of the scope.
Confusing? Let me know, I will try to clarify.
Just a correction, R is the the resistance of the oscilloscope + the resistance of your resistor ([itex]47K\Omega[/itex]).
Only if the cap is discharging through both. If he puts the o-scope directly across the cap, it will give only the R of the scope.
I wasn't sure by the description of the setup which was the case.
Other than that, you agree with this method? I wonder if there is a shorter way to figure this out. Any ideas?
He only said that "the voltage source is removed" so I thought the original resistor is not removed.
But yes, I agree with your method and that's how I'd do it. The easiest way is to connect the scope directly to the source, or to an ohmmeter, but I don't think that's allowed. :wink:
Ah, I see. Thank you all very much. That was very helpful.
  • · Replies 62 ·
