Understanding Schwarz Inequality: A Primer on Real and Complex Spaces
  • Context: Graduate
  • Thread starter Thread starter jammidactyl
    Inequality
The discussion revolves around the Schwarz inequality, its implications in various mathematical contexts, and the properties of real and complex spaces. Participants explore the relationship between algebraic and topological structures, particularly in relation to inner product spaces and differential geometry.
  • One participant expresses confusion about the Schwarz inequality and its derivation from Euclidean distance, suggesting that it obscures the underlying properties of R^n.
  • Another participant notes that the Cauchy-Schwarz inequality in R^n is a specific case of a more general inequality that holds in any inner product space, implying that the structure of a field is necessary for its proof.
  • A participant raises questions about the topological and algebraic properties of R^n that contribute to its differentiable structure, seeking further reading on the topic.
  • Discussion includes the notion that there is no unique construction in differential geometry, with one participant providing an example involving algebraically closed fields and rational functions.
  • Some participants clarify that in algebraic geometry, the focus differs from differential geometry, particularly regarding the presence of length and angle measures, and the implications for curvature.
  • Concerns are raised about the distinction between differential geometry and differential topology, with a participant questioning the utility of the tensor algebra over algebraic varieties in addressing common inquiries.
Participants express differing views on the relationship between algebraic geometry and differential geometry, with some emphasizing the necessity of curvature in the latter. There is no consensus on the implications of the tensor algebra over algebraic varieties or the distinctions between the fields.
Participants mention various mathematical structures and properties, such as inner product spaces, ordered rings, and algebraically closed fields, without resolving the complexities or dependencies involved in these discussions.
This discussion may be of interest to those studying analysis, algebraic geometry, differential geometry, and the foundational properties of mathematical spaces.
jammidactyl
I'm thoroughly confused by the Schwarz inequality.
In many books on analysis, the author defines the Euclidean distance and then shows that the distance function is a metric, ie the Schwarz inequality holds. This isn't very satisfying as I feel it masks the properties of R^n that generate this relation.
In reading on Wikipedia, I came across the topological idea of a uniform space. Although I don't quite understand the characterization of a uniform space, it satisfied me to read that we could salvage some parts of analysis without resorting to a real-valued distance function. We can still formalize the notion of "relative closeness".
From a simple algebraic viewpoint, one can easily define an absolute value in an ordered ring. This order relation satisfies the triangle inequality, and I also believe it satisfies the Schwarz inequality. So is every ordered ring a "metric space" where the standard metric takes on values from the ring?
This makes sense until we look at the complex plane. It's not an ordered field (or ring) but we can still define a absolute value. This work because we identify the complex plane with R^2... but that brings me back the original question, what properties of R^n allow us to prove the Schwarz inequality?
If this seems like a half-baked post, it is... I'm having a hard time even formulating my question and wanted to see if somebody could direct me to further reading on these ideas (my home library is coming up short).
Um, well it might help you to know that the C-S inequality in R^n is a special case of the C-S inequality that holds in any inner-product space. That is, although there might be more abstract generalization of the C-S inequality, the only property/structure you need to prove the case in R^n is that of an inner product space, hence it holds in any inner product space.
An inner product space is a vector space together with a function of two variables mapping into some field satisfying a few axioms. So it seems that a ring is not sufficient for some reason I have no intention of investigating a 5h42 AM; it has to be a field.
Ah... right an inner product space.
I'll tell you what really motivates these questions. I'm having trouble sorting out the topological and algebraic properties of R^n that generate the differentiable structure. I found an article that talks about some of the ideas that interest me:
Geometry, calculus and Zil'ber's conjecture
http://www.math.ucla.edu/~asl/bsl/0201-toc.htm
What field does this fall under? I'm very much interested in logic, but also differential geometry.
Thanks!
There isn't going to be a unique construction.
Anyways, the ordering relation isn't necessary to do differential geometry. The simplest case is:
Let k be an algebraically closed field.
Let [itex]K = k(t_1, t_2, \ldots, t_n)[/itex] be the field of rational functions over k in n variables.
Then the module [itex]\Omega^1_{K/k}[/itex] of differential forms of K over k is abstract K-module generated by the formal basis elements [itex]dt_i[/itex]. The derivation [itex]d:K \to \Omega^1_{K/k}[/itex] is uniquely determined by the sum rule, the product rule, and the constraints [itex]d(t_i) = dt_i[/itex].
We obtain the cotangent space at any point P in k^n by further imposing the relation that [itex]f dt_i = g dt_i[/itex] whenever f(P) = g(P).
those of us inalgebraic geometry, where that construction arises, do not consider ourselves to be doing diffrential geometry, even we are taking derivatives. when we use the phraSE differential geometry we mean there is also a length and angle measure present. so curvature is an essential ingredient of differential geometry.
i.e. not aLL CIRCLEs SHOULD BE ISOMORPHIC IN DIFFERENTIAL GEOMETRY, as they are in algebraic geometry.
Ah! I never really formed a mental distinction between differential geometry and differential topology.
My point still stands, I think -- we can still give an algebraic construction of the cotangent sheaf, and thus construct the tensor algebra over our variety. From there, we can do (the algebraic analog of) anything we want, such as study the geometry arising from a metric tensor. On algebraic varieties, though, I only ever hear people talking about differential k-forms, and occasionaly tangent vectors. Is there a serious flaw in the theory of the tensor algebra over an algebraic variety, or is it just not useful for the questions often asked?
  • · Replies 19 ·
  • · Replies 16 ·
