Thread Closed
A cyclic group proof
Share Thread Thread Tools
Apr25-07, 04:43 PM   #1
Recognitions:
Homework Helper Homework Help
I came across a theorem the proof of which I don't quite understand.
The theorem states that every infinite cyclic group is isomorphic to the additive group Z.
So, the mapping f : Z --> G given with k |--> a^k, where G = <a> is a cyclic group, is an epimorphism, which is quite obvious. Now, in order to show that it's an isomorphism, one should show that it's a monomorphism, i.e. that the kernel is trivial. So, we have Ker f = {k from Z such that a^k = e}. Now, Ker f contains 0, but how do I show that it only contains 0?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr25-07, 04:47 PM   #2
Recognitions:
Use the fact that the groups infinite.
Apr25-07, 04:56 PM   #3
Recognitions:
Quote by StatusX View Post
OK, but I'm not really sure how. The book says that, since Ker f is a subgroup of Z, and if it's non trivial, then we have Ker f = <m>, where m is the least positive integer such that a^m = e. I understand that, but I don't see how it proves anything.
Apr25-07, 05:56 PM   #4
Recognitions:
The group is cyclic, so it has a generator, x, so every element is equal to x^n for some integer n. x has infinite order, since the group is infinite, hence x^n=x^m if and only if n=m. Hence the group has an obvious isomorphism with Z.
Apr25-07, 06:18 PM   #5
Recognitions:
Suppose a^k=e, k=/= 0. Then a^k+1 = a, and you just discovered your group is finite
Apr25-07, 06:29 PM   #6
Recognitions:
Quote by matt grime View Post
I'm probably missing something, but where does this fact about injectivity come from?
I know the isomorphism is obvious, but I don't understand some formal details.
Apr25-07, 06:30 PM   #7
Recognitions:
you have proved every cyclic groupis isomorphic to a quotient of Z. the only quotient that is infinite is the quotienht by {0}.
Apr25-07, 06:38 PM   #8
Recognitions:
Quote by radou View Post
Suppose not, then..... (this is something you must have proved on the first exercise sheet in the course)
Apr26-07, 12:03 PM   #9
Recognitions:
Okay, so suppose there exist integers p and q, p=/=q, such that a^p = a^q. Then we have a^(p-q) = e, so p - q belongs to Ker f = <m>, where m is the least positive integer such that a^m = e.
Again, I'm not sure how to proceed.
Apr26-07, 12:36 PM   #10
Recognitions:
No, you're doing this the wrong way. I said x (which you relabelled a) was a generator of this notional infinite cyclic group. Obivously x^m is never e for a generator of an infinite cyclic group unless m=0. Look, the infinite cyclic group is {x^n : n in Z}, so the isomorphism sends x^n to n. It is trivially an isomorphism, the question really has no content: it is just taking logs base x.
Apr26-07, 12:47 PM   #11
Recognitions:
OK, I understand now. I shouldn't have wasted so much time on this.
Apr28-07, 01:24 PM   #12
Recognitions:
Btw, I should have realized earlier how trivial it can be proved.
Assume Ker f =/= {0}. Ker f = <m>, where m is the least positive integer such that a^m = e. Hence, a^(m+1) = a^m*a = e*a = a , a^(m+2) = a^(m+1)*a = a^2 , ... , a^(2m) = a^m*a^m = e, etc. Therefore we have a contradiction with the fact that G is an infinite cyclic group, so Ker f = {0}, which makes f a monomorphism, and hence an isomorphism.
Apr29-07, 03:15 PM   #13
Recognitions:
I don't want to start a new thread, so I'll simply post another thing I'm not sure about in this thread, hoping it will be noticed.
I have to prove that, an infinite group is cyclic iff it is isomorphic to each of its proper subgroups.
(=>) OK, let G = <a> = {a^n : n e Z} be an infinite cyclic group. Since G is cyclic, so is every of its subgroups. Let H < G, where H is a proper subgroup. Then H =<a^m> = {(a^m)^n : n e Z}, where m is the least positive integer such that a^m e H. Consider the mapping f: G --> H given with f : a^n --> (a^m)^n. It is a homomorphism, since f(a^p*a^q)=f(a^(p+q))= (a^m)^(p+q) = (a^m)^p*(a^m)^q = f(a^p)*f(a^q). Further on, it is a monomorphism, since (a^m)^p = (a^m)^q => p = q, since a^m is in G and the elements of G are all distinct. Clearly it is an epimorphism, since Im f = {(a^m)^n : n e Z} (since G is isomorphic to Z), which makes it an isomoprhism, so G is isomorphic to H.
(<=) This is the direction I'm having problems with, so I'd be grateful if someone checked my work and helped me out with a further hint/correction.
Apr29-07, 03:30 PM   #14
Recognitions:
For the first direction, have you proved every subgroup of a cyclic group is cyclic? This is the main part of the proof, but you seemed to have skipped this and focused on the more trivial details. Once you get this, you can just use the fact you showed above that all infinite cyclic groups are isomorphic to Z, and so to each other.
For the other direction, find an x in G that isn't a generator, and use the hypothesis that <x> is isomorphic to G.
Apr29-07, 03:51 PM   #15
Recognitions:
It is a proved theorem in my book, so I used it.
OK, so let the infinite group G be isomorphic to each of its proper subgroups. Let H = <a> be a nontrivial cyclic subgroup of G. But, how do I know a isn't a generator of G? (I can only assume, but that's not enough, I suppose.)
Apr29-07, 03:55 PM   #16
Recognitions:
Let H be a non-trivial proper subgroup of G, and pick an element from H.
Apr29-07, 04:07 PM   #17
Recognitions:
Let a e H, where H < G. Since G is isomorphic to H, for every a^n where n is an integer, there exists a unique element from G mapped to that element, and since G is infinite H = <a> is an infinite cyclic subgroup, and hence isomorphic to Z, which makes G isomorphic to Z, so G is an infinite cyclic group. (I feel there is something wrong with my logic somewhere.)
Thread Closed
Thread Tools
Similar Threads for: A cyclic group proof
Thread Forum Replies
cyclic group question Calculus & Beyond Homework 3
another cyclic group question Calculus & Beyond Homework 2
Showing that a group isn't cyclic. Calculus & Beyond Homework 5
Cyclic Automorphism Group Linear & Abstract Algebra 1
Klein and Cyclic group Linear & Abstract Algebra 9
