Conservation of Energy involving Spring
The problem involves a 30kg mass attached to a massless spring with a force constant of 1000 N/m. The mass is released from rest, and the discussion centers on the maximum extension of the spring, considering the conservation of energy principles and the effects of oscillation and energy dissipation.
  • Participants discuss the application of conservation of energy to find the maximum extension of the spring and question the reconciliation of energy values at equilibrium. There is exploration of energy transformation and dissipation during oscillations.
Participants are actively engaging with the concepts of energy conservation and dissipation. Some guidance has been offered regarding the nature of energy loss and the behavior of the spring during oscillation, but there is no explicit consensus on the resolution of energy discrepancies.
Participants are considering the effects of air resistance and potential energy transformations in the context of real-world applications versus theoretical models. The discussion acknowledges the complexities introduced by non-ideal conditions.
Beespring
Given a problem : A 30kg mass is attached to the lower end of an almost massless spring with force constant k=1000N/m. The mass is then released to rest. Ignoring air resistance, what is the maximum extension of the spring? Note : The spring is said to obey Hooke's Law [F=-kx; Elastic Potentaial Energy=(1/2)(k)(x)(x)] _
I use Conservation of Energy to solve this problem whereby the original Gravitational Potential Energy mgh is converted 100% to the Elastic Potential Energy (1/2)(k)(h)(h) when the spring is monentarily at rest, where h is the max extension of the spring. I get h=0.6m.
When the mass reaches its final equilibrium position, the tension of the spring is equal to mg, i.e. khe=mg where he is the extension length at equilibrium. Therefore he=0.3m. The Elastic Potential Energy stored in the spring is then (1/2)(1000)(0.3)(0.3)=45J. This is half the change in Gravitational PE from before the mass is released which is mgh=30(10)(0.3)=90J [take g=10m/s^2]. How does this reconcile with the Principle of Conservation of Energy?
I believe I can answer this one.
When you used the conservation of energy method to find when the energies equal each other, that is the MAXIMUM displacement. When you drop something onto a spring, you'll notice that the spring will initially compress a lot, and when it reaches equilibrium (stops bouncing), the spring will be compressed a lot less than it was when you first dropped the object.
But where has the 45J of PE gone to & how?
Hi Shawn,
Thks for your reply. I understand about the oscillations the spring undergoes before coming to its equilibrium rest, that's why I use the Conservation of Energy method to find the maximum extension. But where has the 45J of PE gone to & how?`
In reality, it goes into heat in the spring.
In theory, it doesn't go anywhere at all. The spring will oscillate forever.
Take a piece of metal, and bend it back and forth a lot; the metal will get very hot.
You can get a nice piece of metal from inside your computer where the drive bays are (unless you've already taken those out).
Spring slows down because of air resistance?
Thks for your prompt reply, Shawn. I got the same answer from other websites after posting the question too. Just to confirm, the spring slows down because of air resistance in reality? Which is doing negative work done thus reducing the total mechanical energy.
Yep that's correct.
  • · Replies 58 ·
  • · Replies 20 ·
