| Thread Closed |
antiderivatives |
Share Thread | Thread Tools |
| Apr26-07, 02:57 AM | #1 |
antiderivatives
How do I find the antiderivative of
(12e^2x-5) My attempt: u=2x-5 u'=2 12u^u x 2 24e^2x-5 What do I do next? |
| Apr26-07, 03:02 AM | #2 |
You started right, u = 2x-5, du = 2 dx. I'm not sure what you're trying to do in the next step. What you should try to do is 6du = 12 dx because you want to match the 12 in your original equation. With these subsitutions your new integrand is 6e^u.
| Apr26-07, 08:18 AM | #3 |
Recognitions:
We let u = 2x - 5 Then we find the differential of u, [tex]du = 2 dx \Rightarrow dx = \frac{du}{2}[/tex], now, with the substitution above, we'll change every x's in the expression into our newly-defined variable u: [tex]\int 12 e ^ {2x - 5} dx = 12 \int e ^ u \left( \frac{du}{2} \right) = 6 \int e ^ u du = ...[/tex] Can you go from here? After having its anti-derivative in terms of u, we should change u back to x, and complete the problem. Is it clear? :) |
| Apr26-07, 09:54 AM | #4 |
antiderivativesYou can either think "break that 12 into 6* 2 so 6e^(2x-5) (2dx) becomes 6e^u du" or write dx= (1/2) du so 6e^(2x-5)dx becomes 12e^u ((1/2)du)= 6e^u du again. I suspect you were thinking of the chain rule when you multiplied by 2. That applies to differentiation. The anti-derivative is the opposite of the derivative so you divide by 2 rather than multiplying. By the way- notice my use of parentheses. e^(2x-5) is NOT the same as e^2x- 5. Most people would interpret that latter as (e^(2x))- 5 and some might even interpret it as x(e^2)- 5. Use all the parentheses you need to make your meaning clear. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: antiderivatives
| What is the antiderivative of x^2 + (5/x^5) +cos9x - e^-7x? | Calculus | 3 | ||
| Antiderivatives | Calculus & Beyond Homework | 6 | ||
| How to get (secx)(tanx) from (1/cosx)(sinx/cosx)? | Calculus | 8 | ||
| antiderivatives | Calculus & Beyond Homework | 2 | ||
| antiderivatives x^n | Calculus & Beyond Homework | 14 | ||
