Calculate Astronaut's Velocity After Throwing Oxygen Tank | Outer Space Question
  • Thread starter Thread starter Mike667
    Space
The problem involves an astronaut in space throwing an oxygen tank and seeks to determine the astronaut's velocity after the action. The subject area pertains to conservation of momentum in a physics context.
  • Participants discuss the conservation of momentum as a relevant principle, with some questioning the sign convention for velocity. There are attempts to calculate the astronaut's velocity based on the momentum before and after the throw.
The discussion is ongoing, with multiple interpretations of the astronaut's velocity being explored. Some participants have provided insights into the sign convention and the nature of speed versus velocity, but no consensus has been reached on the final answer.
There is a focus on the distinction between speed and velocity, as well as the implications of direction in the calculations. The problem is framed within the context of a homework assignment, which may impose certain constraints on the discussion.
Mike667
A 63 kg astronaut at rest in space throws a 10 kg oxygen tank with a speed of 12 m/s. What is the velocity of the astronaut immediately after throwing the tank?
Which formula would I use to solve this? Thanks in advance.
Conservation of momentum. Here, the total momentum before was zero. so th etotal momentum after will be zero.
Yes, that's what i was thinking. thanks again.
Is the answer 1.9 m/s?
I get ...120/63.
denverdoc said:
I get ...120/63.
oh really?:rolleyes:
actually, its -1.9 m/s because the astronaut goes backwards.
actually, its -9.1 m/s because the astronaut goes backwards.
I think you may mean -1.9m/s
Haha, yeah ill change it.
Yes, and I actually chose the sign convention as such. Good lord trying to be helpful. And you'll notice, the question states the problems in terms of speed and asks for velocity. Either answer is correct.
  • · Replies 44 ·
23K
